586,371 active members*
3,397 visitors online*
Results 1 to 9 of 9
    China 3040 parallel port
    Hello, looking for help in a way to hook up a Z touch pad, however my machine has no limit switches.
    The board has no provisions for limits or other plugs, many empty holes to soldier wires to the board.
    I did find a program that works with Mach3 for setting everything up and finding the proper pin once hooked up, but recommends pin 15....I tried ringing it out with my meter, but find nothing without power that has continuity.
    Any help appreciated
    Jun 2005
    1730
    Re: China 3040 parallel port
    You could get a generic Mach3 CNc control board that comes with inputs and outputs, they sell for $40 to $60 on eBay
    I've got 2 different boards, but haven't idea what to fo with them. The mill works great like it is, just want to add the Z probe
    I can fix about anything, just never dealt with these before. I repair Tube amplifiers but am self taught...lol
    Jun 2005
    1730
    Quote Originally Posted by Bartman01 View Post
    Hooking up and modifying these the CNC control boards is not difficult. Especially if you already do stuff with electronics like tube amplifiers. Post pictures of the boards you have including the one in the machine, I can probably guide you on how to add a Z probe. What software are you running with the mill right now, Mach3?
    This is the board I have, just found this .pdf
    https://www.vallder.com/images/product_details_images/mach3_5-axis_board/Mach3-5-Axis-Interface%20Board.pdf
    Quote Originally Posted by CNCMAN172 View Post
    Yes, Mach 3 and drawing and post-processing with solidworks
    The board in the machine has the 4 pin plugs for the X, Y, Z, A axis that would plug right into the breakout board. It would be wiring the drivers that would throw me.
    Just have to make sure I get the X, Y, Z, A drivers in the correct spot.
    Also has a plug on the back of the power box that plugs into the machine. Not a parallel plug, but similar.but I can always ring that out with my meter for the mototrs.
    Jun 2005
    1730
    This board has a tool setter input available, this is all you need to do is configure it for that port/pin. The axis inputs are clearly labeled, very easy stuff.
    I see that now that I have a schematic. Thanks for the suggestions. I will hit you up if I have any snags
  1. Chinese 3040 parallel port machine and MK3/4
    By JerryBurks in forum PlanetCNC
    Last Post: 06-10-2019, 07:39 AM
  2. Replies: 3
    Last Post: 04-20-2019, 11:23 PM
  3. CNC 3040 Parallel port pinout
    By berlinmille in forum Chinese Machines
    Last Post: 09-15-2017, 01:53 PM
  4. parallel port dead with pc-suggestions for purchasing usb/ethernet to parallel port?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 08-19-2015, 11:32 AM
  5. arduino parallel port hack for Chinese 3040
    By RunForrestRun in forum USB, RS232, PARALLEL etc
    Last Post: 05-07-2015, 05:59 PM
