586,655 active members*
3,066 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki NTX1000 Tool Spindle Problem
Results 1 to 2 of 2
    I have a 2011 Mori Seiki NTX1000S that is getting the error SP9031 S2 SSPA : 31 MOTOR LOCK OR DISCONNECT DETECTOR. The tool spindle isn't under load, the problem is that the tool spindle doesn't even start up about 5 percent of the time, it just goes in reverse about a quarter rotation and then gets the error. Now it won't even index the tool spindle for a tool change, the spindle just stutters and moves a bit. I had Fanuc out to change the spindle amp and the sensor in the spindle, but nothing helped. DMG Mori does not know what the problem is.The machine has been down for three weeks now, so it's really frustrating. I am hoping that someone on this forum has some idea on what the problem is. Thank you, I really appreciate any help.
    Re: Mori Seiki NTX1000 Tool Spindle Problem
    Quote Originally Posted by Rational2 View Post
    Looks like the the problem come from the speed sensor or the feedback cable.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Mori Seiki NT Tool-Spindle Overtravel Near Tailstock
    By swihartb2 in forum Mori Seiki Machines
    Last Post: 08-24-2022, 09:08 PM
  2. Mori seiki spindle problem
    By Bethk in forum Mori Seiki lathes
    Last Post: 09-05-2019, 12:30 AM
  3. mori seiki FL-2 problem
    By cnyttbircan in forum Mori Seiki lathes
    Last Post: 10-21-2013, 09:58 PM
  4. SL-25B Mori Seiki Lathe Spindle Problem
    By Electronsurf in forum Mori Seiki lathes
    Last Post: 10-01-2011, 02:14 PM
  5. mori seiki mill with a spindle problem
    By imwllc in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2005, 12:31 AM
