586,102 active members*
2,627 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help! Fanuc 18t RS 232 File Read & Write
Results 1 to 10 of 10
    Feb 2024
    8
    So I’ve been at this for 2 days and no luck I was able to setup laptop with dnc software.
    Settings are
    Com 3
    Data Bits : 3
    Parity : Even
    Protocol : ASCII
    Baud Rate : 9600
    Stop Bits : 2
    Hand shaking: Xon/Xoff
    Shows from pc side it’s transferring file over
    On controller side I’m in the program directory
    I’m typing in file name
    O0002.ncc then I click OPRT > READ > EXEC
    For sending files out I do the same but
    OPRT > PUNCH > EXEC
    All I get is an Alarm with error
    233 Device Busy
    Tried attaching photos but files too big I can send via email if anyone wants to see settings on machine.
    Thank you!
    Aug 2009
    1573
    Re: Help! Fanuc 18t RS 232 File Read & Write
    ...the Data Bit should be 7 and sounds like a Cable problem. There are few different ways to interface using RS232C. How do you have your cable wired or type Cable? Null Modem is what you need I think.
    DJ
    Apr 2012
    85
    zeroexa,
    It may be that the PMC is in ONLINE mode. Check parameter 24.
    If it is anything other than "0" it may indicate that "ONLINE" was turned on at some point.
    Try change to "0".
    You may also got to PMC Maint screen and look for "MONIT" softkey. Once pressed go to USE/NOT USE and use L/R cursor to change state to "NOT USE".
    Feb 2024
    8
    Quote Originally Posted by machinehop5 View Post
    DJ
    This actually a typo on my end it’s 7 bit using this cable from Amazon Usangreen USB to DB25 Male Programming Cable for Fanuc 15 16 18 21 Series RS232 Serial RS232 PC Connect Your Device CNC DNC Software Flow Control CNC-SW-25M
    Feb 2024
    8
    Quote Originally Posted by freakycnc View Post
    zeroexa,
    Try change to "0".
    Ah ok so I don’t need this on at all?
    I thought I was supposed to turn on that monitor online to use since it shows rs232 and the settings for it?
    Nov 2007
    352
    RS232 needs a null modem cable wither its from the control to 9 pin on latop or USB -----------Check you have this first ----------If a problem usually you can download/output to Laptop but you cant Upload/input to Machine ?
    Feb 2024
    8
    Quote Originally Posted by lshingleton View Post
    This is cable I’m using seems to show it’s connecting
    https://a.co/d/168Dwie
    What is process of loading in files?
    / exporting? It doesn’t seem to be clear on the manual I found.
    Feb 2024
    8
    Can anyone list the order of operation to load in / export files via RS232 from a Fanuc 18T just to verify I’m doing that part correctly.
    Any settings I need to have on or off.
    Any help is greatly appreciated thank you.
    Nov 2007
    352
    Machine in Edit and cable connected ------best to connect cable before power up exernal computer/laptop
    Start your connection software and set to recive a file and then on the control punch in the number O1000 or what ever file is and hit output and see what you get on your laptop ?
    May 2016
    26
    Could you solve the problem?
    What serial communication software are you using?
    I’m using COMMUNICATION SOFTWARE FOR FANUC CNC with the same FANUC CNC.
    It is specially designed for FANUC CNC though it can be used also with other CNC.
    It has several built-in help menus that show you how to use it with your CNC.
    You can download it from “The SOFTPEDIA· web page.
  1. okuma & howa 2sp v80 fanuc 18t turret alignment
    By brybry-0104 in forum Okuma
    Last Post: 01-12-2021, 07:12 PM
  2. pls, a few questions about file read / write
    By deadlykitten in forum Okuma
    Last Post: 07-22-2019, 05:01 PM
  3. Replies: 1
    Last Post: 11-23-2014, 04:12 PM
  4. Write machine status to RS-232 interface
    By Bernau in forum Fanuc
    Last Post: 01-20-2012, 03:16 PM
  5. Read Write-file
    By CNC-Span in forum SIEMENS -> GENERAL
    Last Post: 03-11-2011, 02:22 PM
