586,103 active members*
3,799 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Press Brake with Linear Encoders with a Reference Mark: How to wire to Kanalog Board.
Results 1 to 6 of 6
    Jul 2004
    235
    Greetings all,
    Press Brake with Linear Encoders with a Reference Mark: How to wire to Kanalog Board. I have wire in incremental Encoders before.
    Is there documentation as to how to wire a Quadrature Incremental Encoder with a Ref+ and Ref- also?
    Thanks so much!
    - Jeff
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    May 2006
    4045
    Re: Press Brake with Linear Encoders with a Reference Mark: How to wire to Kanalog Bo
    Hi Jeff,
    Encoder Ref Marks are handled in KFLOP/Kogna Software so can be connected to any available input. Differential signals can be connected to any unused A or B differential encoder input. Normally Kanalog JP2 is available. See Kanalog JP1/JP2 Differential Inputs.
    For examples of how to home with index pulses see Axis Homing and Indexing.
    TK
    http://dynomotion.com
    Jul 2004
    235
    Thanks Tom... looks good to me! Will give it a go!!
    - Jeff
    Jul 2004
    235
    Next thing I am wondering?
    How can I scale an analog input. The input is 7 to 1907. As wired with a potentiometer. I want that input to be scaled to 0 - 100. How can I do that?
    Thanks!
    May 2006
    4045
    Hi Jeff,
    What is the input used for? That would be (input - 7.0) * 100.0 / (1907.0 - 7.0)
    TK
    Jul 2004
    235
    I am using 3 different Potentiometers as inputs. I will use 1 analog output to supply the 10vdc to the three pot's.
    Then the first pot. and analog input will be used to scale the dwell time after the bend on the press brake... 1 - 5 seconds.
    Then the second pot will scale an offset to be put into the gain of the axis two. This will be anywhere from 0 - 250 thousands of an inch.
    The third will be used to control the pressure setting of the press at 1 - 100 percent.
    I will have a program running on the Kflop. No computer hooked up for running the machine, once dial in.
    Thus I need to scale what ever the pot's are reading. I am using 10 turn pot's for accuracy.
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. Replies: 1
    Last Post: 01-21-2023, 12:32 PM
  3. press brake can't find reference point
    By Andriy77 in forum Bending, Forging, Extrusion...
    Last Post: 09-07-2016, 10:50 PM
  4. Linear encoders + kanalog. Wiring question
    By Alex101 in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-28-2015, 07:26 AM
  5. WTB: linear bearing system for press brake
    By sdubfid in forum Want To Buy...Need help!
    Last Post: 12-20-2009, 10:29 AM
