586,443 active members*
2,924 visitors online*
    Nov 2007
    Millplus error
    Hello,
    We have sometimes a problem with Z-movements on our DMU125. It's erro Z07, which has something to do with the Z-axis motorencoder.
    So today I replaced the encoder in a Siemens 1FT06 motor.
    I restarted the control but it shut itself down with an error E07 and I could do nothing.
    So I placed back the old encoder, but after restarting it shut down again with error Z68, which means no motor current.
    Did I destroy de Z-axis drive?
    What should I do to check this?
    Feb 2013
    Re: Millplus error
    Dear sir,
    how did you solve problem
    I have DMU 80T and I have two alarms Z50 and Z68
    what should I do to solve problem
    Nov 2018
    bonjour
    j ai un dmu 50 v millplus
    j ai la même erreur z50 avez vous résolu votre problème.
    que dois je faire?
    cordialement.
  1. DMG DMU200P MILLPLUS - M56 & M57
    By PeterTheWolf in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-04-2017, 11:04 PM
  2. DMU 50V Millplus error E60
    By paris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-01-2017, 09:46 PM
  3. Millplus question.
    By suckerdave in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-28-2014, 01:12 AM
  4. DMU 60T Millplus
    By moovi in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-28-2014, 01:03 AM
  5. DMU 80T millplus control
    By klinkcnc in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-18-2010, 09:46 PM
