586,121 active members*
3,139 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > new desk top build first tests of movement.
Results 1 to 7 of 7
    Apr 2007
    273
    i started this a few months back but it started with me buying a cheap $350 machine because i was curious what you could get for so little, and the short answer is not a whole lot but it inspired me to see what i could do taking what i liked from that machine and doing away with all the stuff i did not like and ended up with this machine. the cheap import does have the function to become a laser engraver so maybe at some point i will use it for that. but i just got things buttoned up to do a propper test on movement. so i figured i would share here.
    https://www.youtube.com/watch?v=X9-AbciKtME
    Re: new desk top build first tests of movement.
    Very nice, thanks for sharing.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Apr 2007
    273
    i have not really had a ton of time to play around with cutting on this machine. i jogged across some aluminum and quickly realized the need to close this machine in. even with it closed in it still manages to get chips out and about where they should not be this is just a short video of some cutting trying to figure out how much i can push things on this machine.https://youtu.be/YhD9gpmux-I?si=eo38DkT2tI41HoXO
    Apr 2007
    273
    starting my first real project with this machine to give it a real test actually making something. i would probably go about doing these different if i had more to work with but it was a good test on what i think will be a strong point with this machine. A picture of the end result and a video link if you want to see how the machine did.
    Attachment 503456
    https://youtu.be/5tWAAi_QWS8
    Nov 2014
    724
    Quote Originally Posted by machinedude View Post
    Is it just me or does the simulation go in the opposite direction of the machine (or vice versa)? Looks smooth.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Apr 2007
    273
    no you are correct but that is fixed, i had trouble getting the tandem axis set up right at first.
    Mar 2024
    10
    hi friend,
    we run a store for all kinds of machine components.Linear bearings,shaft holders,couplings,Manual Screw Jacks,Press plates,as well as screws and bolts,etc.Please feel free to email me ([email protected] )if you have any items in demand. visit our site at https://www.msmstore.com/
  1. Need help setting up desk top cnc with mach 3
    By dorset=wooden in forum Community Club House
    Last Post: 12-24-2013, 05:22 PM
  2. The best Desk top laser on the market!
    By Hurricane21 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-09-2012, 11:40 PM
  3. MasterCam from desk top to machine computer
    By WoodMizer in forum Mastercam
    Last Post: 02-07-2012, 10:56 PM
  4. Desk Top Resources exceeded
    By lkenney in forum Surfcam
    Last Post: 10-27-2009, 01:15 AM
  5. can i run a desk top laser with generator
    By spacer777 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-22-2009, 06:56 AM
