586,096 active members*
3,208 visitors online*
Thread: 1005 error
    Apr 2009
    6
    1005 error
    1005 error in a robodrill wontread the program
    Re: 1005 error
    Quote Originally Posted by chuk View Post
    It looks like the switch issue.
    The switch is located on the front of the spindle. There is an access panel if you drop z axis all the way down.
    It has 2 bolts on it.
    Took that off and the switch is there.
    The switch could be stuck. clean it and the laser should come back on.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Trump TLC 1005 marking help
    By CncApp in forum Uncategorised MetalWorking Machines
    Last Post: 06-02-2023, 07:00 PM
  2. Variable 1004 and 1005
    By Joshgeorge696 in forum Drilling- and Milling Machines
    Last Post: 02-24-2022, 07:36 PM
  3. trumpf lasercell 1005
    By qotato in forum Commercial Laser
    Last Post: 03-07-2018, 03:27 PM
  4. MyCenter 0 I80 controller #1005 error
    By fred4936 in forum Kitamura
    Last Post: 04-18-2017, 08:27 PM
