586,116 active members*
3,455 visitors online*
    Jul 2004
    235
    If (Check) {Do Something}... ?
    Greetings,
    Working of a program with Home Limit Input Bit 1034, Peddle for Go which is Input 1033, and Lower limit which is Input 1035.
    This is for a simple punch machine control. Using Konnect board for I/O and three inputs.
    When I push the peddle I want axis 2 to go down. When I let off the peddle it should stop.
    This code below works... for this.
    ______________________________
    #include "KMotionDef.h"
    main()
    for(;
    if (!ReadBit(1033))
    while (!ReadBit(1033));
    Jog(2,-100);
    if (ReadBit(1033))
    while (ReadBit(1033));
    Jog(2,0);
    _________________________________________
    Now I need to to stop this motion also if the lower input (1034) comes on. Then home to the upper input (1034).
    I have tried to do this, but have had little luck with the code... and trying to add the other monitoring... Think I am just missing something?
    Thanks in advance for any help?
    - Jeff
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    May 2006
    4045
    Re: If (Check) {Do Something}... ?
    Hi Jeff,
    Now I need to to stop this motion also if the lower input (1034) comes on. The home to the upper input (1034).
    Is that a typo? Can you explain more clearly?
    TK
    http://dynomotion.com
    Jul 2004
    235
    Tom,
    Yes that was a typo! Go figure!!
    See here for what I want to accomplish to start. This will get more complicated later, with a fast and slow speed input. Not worried about that yet!
    Attachment 502902
    May 2006
    4045
    Hi Jeff,
    A general way to handle multiple events using a single Thread is to use a State Machine, See the untested example below:
    Code:
    // Press Brake control
    enum { IDLE, JOG_DOWN, DELAY, HOME };  // states
    #define BIT_PEDAL 1033
    #define BIT_NEG_LIMIT 1035
    #define BIT_TOP_LIMIT 1034
    #define BIT_AUTO 46
    #define ZAXIS 0
    #define DWELL 2.0 // delay at bottom seconds
    void main()
        int state=IDLE;
        double DelayTime;
        for (;;)
            switch (state)
            case IDLE:
            if (ReadBit(BIT_PEDAL))
                Jog(ZAXIS, -100);  // Jog down
                state = JOG_DOWN;
            break;
            case JOG_DOWN:
            // stop Jogging down if pedal released and not Auto mode
            if (!ReadBit(BIT_PEDAL) && !ReadBit(BIT_AUTO))
                Jog(ZAXIS, 0);  // Stop
                state = IDLE;
            else
                // hit negative limit?
                if (ReadBit(BIT_NEG_LIMIT))
                    DelayTime = Time_sec() + DWELL;
                    state = DELAY;
            break;
            case DELAY:
            if (Time_sec() > DelayTime)  // Dwell finished?
                Jog(ZAXIS, 400);  // Begin Homing
                state = HOME;
            break;
            case HOME:
            if (ReadBit(BIT_TOP_LIMIT))  // Homed?
                state = IDLE;
            break;
    TK
    Jul 2004
    235
    Thanks so much!
    I am getting something accomplished now! This is working!! Of course I will modify to the specifics according to the machine.
    I will be using the the Kflop and Kanalog control boards to do this.
    The program will have a couple of more inputs, for different modes or ways of operating the code sequencing.
    The State Machine idea is a good thing. I like that.
    Thanks - Jeff
  1. Replies: 5
    Last Post: 01-27-2018, 03:23 PM
  2. Check It Out
    By Journey_Man in forum Syil Products
    Last Post: 11-02-2009, 05:15 PM
  3. Check this out !!
    By weirdharold in forum UG NX
    Last Post: 07-06-2009, 12:13 AM
  4. Replies: 3
    Last Post: 01-19-2007, 02:59 PM
