586,032 active members*
2,960 visitors online*
Results 1 to 14 of 14
    Jul 2005
    340
    lathe programming learning ?
    Hello everyone ,
    currently I`m waiting for SL-20, in days or weeks i`ll get she in my shop,
    there is only one problem : I have no idea of programming a lathe , I only
    know how to mill, for programming I use EdgeCAM, and I know that I will
    never type a program im Gcode, there is no sense in milling , but these
    could be other in turning, so I have 2 ways to learn , 1: CAM 2: Cycles.
    Which way to choise ? Is there any sense to learn cycles having CAM ?
    I don`t know what type of work is waiting for me, this could be anything.
    What is Your opinion ?
    Is there a software I can download ( free ? ) that helps writing cycles
    and simulate them ?
    I don`t wish to get an colision
    Nov 2007
    479
    If you know how to mill, than turning should become a breeze. Z = length, X = diameter or you could just call your Edgecam rep and have them upgrade your cam package with all the lathe features. Your HFO rep should be able to help you in with training on the control.
    Feb 2007
    10
    Yes you should learn your g code and all your canned cycles since it is a lathe, programing becomes much faster and more productive , here is a tip for you since it is a new machine once you get a few programs in the memeroy you can just copy programs and then edit and manipulate them for your curent program needs p.s. do not use the quick code it is crap.
    Jul 2005
    12177
    Mulcher has the correct idea; make what I call template programs and then edit them as needed and forget about the quick code stuff. I have dozens of template programs and can do things quicker on my TL than I can on a manual machine even if it is only turning or facing. You must have seen pictures I have posted of the tooling parts I have done.
    When you have the machine running if you like I can post some of my programs for you to download and then you can run them in Graphics to follow them. I can also put up pictures of the parts.
    Jul 2005
    340
    I don`t like EC in turning, I`ll try type programs from hand, it will be easier for me if I could see what I do ( some great simulation in PC ? ) now I am a lame in turning I don`t know what for are corrections and what they do if I don`t see it :-)
    Jul 2005
    12177
    Quote Originally Posted by pit202 View Post
    .....I don`t know what for are corrections and what they do if I don`t see it :-)
    When you get going if you have a query just post the code and I will run it through my Haas lathe simulator. By now I think I have found all the error codes and can sort things out fairly quickly.
    Jul 2005
    340
    Now I`m waiting for the service to wake she up from sleep, I`m so curious.
    Nov 2007
    479
    Sweet man, good luck, have fun, and remember to test your first cuts in 5% rapids!
    Jul 2005
    340
    today the first tools for the first job have arrived , and I know the running date : it is monday ;-)
    Attached Thumbnails Attached Thumbnails IMG_7793.JPG   IMG_7794.JPG   IMG_7795.JPG
    Jul 2004
    601
    Nice lathe, your TM-1 is going to have some company now!
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Jul 2005
    340
    Yes, TM-1 looks like a poor toy in comparsion with sl-20
    Mar 2007
    27
    TM-1 Sweet!!
    Feb 2006
    Jul 2005
    181
    Another way to learn is to use the haas lathe workbook
  1. c-axis programming lathe
    By pjmorand in forum G-Code Programing
    Last Post: 04-06-2024, 07:38 PM
  2. Super NTJ LATHE Variable programming
    By mike9696 in forum G-Code Programing
    Last Post: 07-11-2007, 01:42 AM
  3. learning G code programming
    By ldaniels in forum Mach Wizards, Macros, & Addons
    Last Post: 05-08-2007, 07:47 PM
  4. Learning Programming
    By Gujustud in forum G-Code Programing
    Last Post: 01-17-2005, 11:17 PM
