586,655 active members*
2,408 visitors online*
Results 1 to 6 of 6
    Apr 2021
    13
    Question CNC lathe threading cycle G76
    Hi, I've noticed the G76 threading cycle command is no longer supported on the TNGv2 software. That's actually a very convenient feature built into the software so that I don't have to use CAM to output thread gcode every time. Are there any workaround for that? I noticed TNGv2 supports more API and python interface. Has anyone created any customized threading feature interface?
    Mar 2017
    1319
    Re: CNC lathe threading cycle G76
    G76 is supported in TNG.
    Here is example g-code:
    Code:
    (dlgname,Thread)
    (dlg,Position Z, dec=3, def=0, min=-10000, max=10000, setunits, store, param=posz)
    (dlg,Position X, dec=3, def=0, min=-10000, max=10000, setunits, store, param=posx)
    (dlg,Length, dec=3, def='setunit(-20,-1);', min=-1000, max=1000, setunits, store, param=length)
    (dlg,Pitch, dec=2, def='setunit(2.5,0.1);', min='setunit(0.25,0.01);', max='setunit(6,0.25);', setunits, store, param=pitch)
    (dlg,Cut Depth, dec=3, def='setunit(0.1,0.005);', min=0, max=1000, setunits, store, param=cutdepth)
    (dlgshow)
    #<depth>              = [0.614 * #<pitch>]
    #<offset>             = 0
    #<degression>         = 1
    #<compoundslideangle> = 29.5
    #<springpasses>       = 1 ;Number of finishing passes
    #<taper>              = 2 ;0=None, 1=Entry, 2=Exit, 3=Entry+Exit
    #<taperangle>         = 45
    #<taperdistance>      = [TAN[#<taperangle>] * #<depth>]
    (print,Length: #<length>)
    (print,Pitch: #<pitch>)
    (print,Depth: #<depth>)
    (print,Offset: #<offset>)
    (print,CutDepth: #<cutdepth>)
    (print,Degression: #<degression>)
    (print,CompoundSlideAngle: #<compoundslideangle>)
    (print,SpringPasses: #<springpasses>)
    (print,Taper: #<taper>)
    (print,TaperAngle: #<taperangle>)
    (print,TaperDistance: #<taperdistance>)
    M73
    G21
    M3
    G00 Z#<posz> X#<posx>
    G76 Z#<length> P#<pitch> I#<offset> J#<cutdepth> K#<depth> R#<degression> Q#<compoundslideangle> H#<springpasses> E#<taperdistance> L#<taper>
    M5
    M2
    Apr 2021
    13
    Yes, I saw this in the generate-thread tab. However, when I try to use it, it shows this error message.
    Mar 2017
    1319
    Do you have old software version?
    Apr 2021
    13
    No, currently I'm using the TNGv2 on the planetcnc website. If you have older version that works, please let me know the download link and I can have a try. Thanks.
    Mar 2017
    1319
    Export your profile and send me .zip file. Also send me g-code that you use.
  1. Threading Cycle G76 and G92
    By crandalljclj in forum G-Code Programing
    Last Post: 10-25-2014, 04:37 PM
  2. g76 threading cycle
    By Readme00 in forum Mastercam
    Last Post: 06-17-2014, 07:59 PM
  3. Programming lathe threading cycle G76 on a mill.
    By zaebis in forum G-Code Programing
    Last Post: 08-26-2012, 12:29 AM
  4. 1/4 NPT threading cycle (G76)
    By cncwhiz in forum G-Code Programing
    Last Post: 02-02-2012, 01:45 PM
  5. G76 Threading cycle
    By noshibby in forum Fanuc
    Last Post: 07-19-2011, 08:55 PM
