586,271 active members*
3,196 visitors online*
    Jun 2008
    91
    X axis only moves in one direction
    Hi Guys, I haven't used my CNC mill in the last few months and when I started it up today I found that while the Y and Z jog and move are fine, the X controls will only move in one direction, whichever of the directions I click on. I updated the planet CNC software and the board firmware, but it is still the same
    Any ideas? It was working fine last time I used it, and I have not disconnected or reconnected anything other than the mains power
    Les
    Jun 2008
    91
    Re: X axis only moves in one direction
    I saw the similar threads to mine and read up on them. In every case they seemed to recommend going through all the wiring for security, which is what I did. It has fixed the issue, there were some of the screw clamps that were not as tight as they should have been
    Cheers
    Les
    Apr 2003
    540
    You'll just have to troubleshoot. Controller, wiring and steppers.
    Check all cables and wiring for loose wire or connection. If yo have a multimeter check wire continuity.
    If you have a spare motor that makes it a little easier to check them.
    Swap stepper motor with a different one to see if it's motor or something else.
    Swap connections on driver board to see if it's driver or wiring.
    It's just a simple matter of checking and eliminating possibilities.
  1. Z axis only moves in one direction
    By mklotz70 in forum Hobbycnc (Products)
    Last Post: 05-06-2020, 03:55 PM
  2. Z Axis Moves One Direction
    By gabedrummin in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2017, 04:28 PM
  3. Axis only moves in one direction - need help
    By BRobbins in forum Mach Software (ArtSoft software)
    Last Post: 09-18-2016, 03:23 PM
  4. axis moves one direction. help
    By rs4race in forum Benchtop Machines
    Last Post: 01-26-2014, 10:20 PM
  5. Axis moves in same direction
    By mreitt in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2013, 01:32 PM
