587,426 active members*
4,498 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > measuring the positions of a series of holes point to point
Results 1 to 2 of 2
    Aug 2005
    301
    Hi Folks ,
    I have a part that I want to duplicate that has 4 holes . I probe the hole that I want to be X o Y o and set it as such . I move it to the second hole and probe that hole and it does not show me the XY distance or position . I am not sure that I can do it with PathPilot . Can anyone give me any tips on how to do this ?
    Ernie
    Nov 2022
    12
    If you are on the latest version of Pathpilot then you can do this. I'm running 2.10.1 and an not sure if/ which version this was implemented. Here is how I would preform this inspection.
    1. Probe X0Y0 in one of the holes.
    2. On the "rect/circ" tab within probing look for the "find center and: " then select "display results only".
    3. Probe the next hole
    4. The long white dro next to the section referenced in step 2 will show the diameter of the hole probed and the xy coords.
    Quote Originally Posted by ErnieD View Post
    Hi Folks ,
    Ernie
  1. Lasercut 5.3 start point and end point not matched and curve line not smooth?
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2019, 11:26 PM
  2. why the laser not line up (cutting original point does not meet end point)
    By AmyThunderlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-30-2014, 03:30 AM
  3. Replies: 5
    Last Post: 09-25-2013, 05:20 PM
  4. measuring a diameter by x & y point values
    By Doug Tyler in forum Calibration / Measurement
    Last Post: 01-05-2008, 12:18 AM
