586,096 active members*
3,722 visitors online*
    May 2009
    1332
    Where PSU Should be Located?
    Starting work on my control panel for my new cnc and I remember reading the PSU (power supply units) should be located at the top or bottom of a control panel but I don’t remember which one is the correct answer.
    Is it at the top or bottom and why?
    Nicolas
    Aug 2005
    1094
    Re: Where PSU Should be Located?
    It can be either. If the power supply needs cooling, then its placement may be decided on how to plan to cool it, etc.
    this is one layout I used.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    May 2009
    1332
    Nice looking panel you got there Peter. Regarding the location of the PSU I understand. I have 2 PSU each 48VDC, 7.3A which came from the stepperonline kit I bought and each has a cooling fan + I will add another one 24VDC, 10A to supply power to the BOB I bought from the Maker Store (also has its own cooling fan). I plan to install all 3 inside my panel by the top. I will also add a small cooling fan just to move around the air inside the panel.
    I wonder if you would like to comment why stepperonline send me 2 PSU each 48VDC, 7.3A. Is it less expensive than having one 48VDC, 12A? I asked them but no reply yet. Perhaps there is another reason? In any case I plan to connect the heaviest axis to one PSU and the rest to the other PSU.
    Cheers
    Nicolas
    Nicolas
    Aug 2005
    1094
    There have been times when ie used two 7.3A 48v supplies to give a total of 14A.
    In some cases I’ve ran the X and Y axis of one, and the Z and A of the other. The other configuration is to connect the two supplies in parallel. With this you need to check the data sheet for the supplies to ensure that the supplies are able to be configured as such. I always use genuine Meanwell supplies.
    Why you have two supplies instead of one I can’t comment. That’s a question for the supplier.
    When I use two supplies I configure them one above the other.
    Cheers
    Peter.
    May 2009
    1332
    Very good information Peter, many thanks
    Nicolas
    Nicolas
  1. Replacing PSU with higher wattage PSU CO2 Laser
    By Dec0y in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2022, 07:58 AM
  2. CO2 PSU and TUBE ? Can I use a 40w PSU with a 50w tube ?
    By TrickyCNC in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 07-17-2014, 07:36 PM
  3. Where are you located?
    By ref772 in forum Momus Design CNC plans
    Last Post: 01-13-2014, 05:10 PM
  4. Questions about an old control/ its psu/ a new psu/ old servos
    By GM1G in forum CNC Machine Related Electronics
    Last Post: 05-26-2012, 08:56 PM
  5. Where's your PC Located
    By dobrientruckers in forum Commercial CNC Wood Routers
    Last Post: 11-27-2009, 11:55 PM
