586,077 active members*
3,974 visitors online*
Results 1 to 7 of 7
    Jun 2017
    119
    Measure Height.
    Is it possible to make the measure height process go faster?
    I have Z safe height set to 15, and whenever it probes it returns to 15 before continuing with the program. I would like it to go directly to the next line ie Z 3.8.
    The extra Z 0-15 and back down 15 -3.8 takes a lot of time. And when you do this on 1000 parts the time adds up very quickly.
    Jul 2018
    6339
    Re: Measure Height.
    Hi Mremo - Then change the safe ht to 1mm if that is "safe" enough... Peter
    Jun 2017
    119
    Re: Measure Height.
    If that would be under "Probe & measure" then that does not work.
    Mar 2017
    1312
    Re: Measure Height.
    "Measure Height" command is used to measure work offset. After measurement machine goes to height it was before measuring.
    This is usually done before you start program so I'm not really sure what are you referring to.
    Jun 2017
    119
    Re: Measure Height.
    With plasma cutting you do this very often to make sure it is the correct height when piercing. A plate can be crooked, it can be a little bit bent, there can be dross under the plate which makes it uneven. Therefore you use the measure height(floating head) very often with plasma cutting.
    Since I had to scrap my floating head script I have now had to use the measure height included with the software. But it takes to much time. Is it possible to change this script somehow?
    Quote Originally Posted by PlanetCNC View Post
    Mar 2017
    1312
    Re: Measure Height.
    I now know that you are using floating head for plasma cutting but not much more. You need to give more information if you want good response.
    I use G65 P120 macro in postprocesor
    https://cnc.zone/gcode/macros/macro-o120
    Setting that you need is "Return Distance"
    https://cnc.zone/tng/settings/settin...eturn_distance
    Jun 2017
    119
    Re: Measure Height.
    Return distance is set to 1mm. It still goes to z15 before continuing with the program.
    Do I need to add something to the macro? I used a postprocessor you helped some other guy with.
  1. Measure surface height - DRO not being set.
    By Stevembh in forum PlanetCNC
    Last Post: 10-08-2022, 12:05 AM
  2. Measure
    By Eatonbrayer in forum PlanetCNC
    Last Post: 06-16-2017, 07:45 AM
  3. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  4. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
  5. Need measure
    By titoniks in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2006, 07:27 PM
