Evening all Hope all is well??
I am looking to add a line into the end of my post processor from vectric to wincnc that makes the machine go and pop the tool back in the holder is it as simple as adding T0 at the end of the PP??
Here is my PP ( generic but works well for me at the moment )
POST_NAME = "WinCNC Arcs ATC (mm) (*.tap)"
FILE_EXTENSION = "tap"
UNITS = "MM"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 5
LINE_NUMBER_INCREMENT = 5
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"[N] [91][TP_FILENAME][93]"
"[N] G90 [91]ABSOLUTE MODE[93]"
"[N] "
"[N] M5 [91]SPINDLE OFF[93]"
"[N] G53 Z0 [91]LIFT Z TO TOP[93]"
"[N] "
"[N] T[T] [91] GET TOOL [TOOLNAME] [93]"
"[N] "
"[N] [S] [91] SET SPINDLE SPEED RPM [93]"
"[N] M3 [91]SPINDLE ON[93]"
"[N] "
"[N] "
"[N] F[FC] XY [91]SET FEEDRATE FOR X AND Y[93]"
"[N] F[FP] Z [91]SET FEEDRATE FOR Z[93]"
"[N] "
"[N] G00 [XH] [YH]"
"[N] G00 [ZH]"
+ Commands output at toolchange
begin TOOLCHANGE
"[N] M5"
"[N] G53 Z0"
"[N] "
"[N] [91][TOOLNAME][93]"
"[N] T[T] [91] GET TOOL NUMBER [T] [93]"
"[N] "
"[N] "
"[N] G53 Z0"
"[N] "
"[N] "
"[N] G00 [XH] [YH]"
"[N] G00 [ZH]"
+ Commands output for rapid moves
begin RAPID_MOVE
"[N] G00[X][Y][Z]"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"[N] G01[X][Y][Z]"
+ Commands output for feed rate moves
begin FEED_MOVE
"[N] [X][Y][Z]"
+ Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"[N] G02[X][Y][I][J]"
+ Commands output for clockwise arc move
begin CW_ARC_MOVE
+ Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"[N] G03[X][Y][I][J]"
+ Commands output for counterclockwise arc move
begin CCW_ARC_MOVE
+ Commands output at the end of the file
begin FOOTER
"[N] M5"
"[N] G53 Z0"
"[N] T0"
Is it as easy as just adding the line in red??
Regards Tom
