586,094 active members*
4,112 visitors online*
    Nov 2017
    6
    5007 too large distance
    we have a miyano bne-51s cnc with fanuc 18i-TB controller.
    machine started to give 5007 too large distance alarm.
    HEAD1 is working fine, no alarms or issues.
    On HEAD2 i got this alarm on auto,homing and even on JOG move.
    2 of the 3 axis move up 126mm/m speed
    3rd one only moves 78mm/m.
    axis move with no problem on slower speeds, no drive error or mechanical issue
    i have checked parameters around 1400 didnt see any limits.
    tried to crosscheck parameters of HD1 and HD2 and nothing i can figure out.
    any help is much appreciated
    Re: 5007 too large distance
    In the HPCC mode, the machine moved beyond the limit.
    OR
    Due to compensation, point of intersection calculation, interpolation or similar reasons, a movement distance that exceeds the maximum permissible distance was specified.
    Check the programmed coordinates or compensation amounts.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Replies: 2
    Last Post: 10-31-2022, 03:45 PM
  2. retract distance and go to zero.
    By FoxCNC1 in forum Aspire
    Last Post: 02-14-2014, 07:05 PM
  3. Distance between bearings.
    By Oxyd in forum Mechanical Calculations/Engineering Design
    Last Post: 06-07-2011, 09:52 PM
  4. Bearing distance
    By pyrojon in forum DIY CNC Router Table Machines
    Last Post: 05-23-2005, 01:51 PM
