586,111 active members*
3,538 visitors online*
    Aug 2005
    176
    Rotary converter 20hp ST20
    Looking to buy ST20
    Can the 20hp motor be run off a rotary phase converter?
    Rob
    Nov 2013
    4376
    Re: Rotary converter 20hp ST20
    yes, you can but the cost will be huge. Entirely probably you'd have to install a high current single phase supply just to run the phase converter.....might be cheaper
    just to get three phase installed from the outset.
    Phase Perfect is a well respected US brand, far from the cheapest I would expect, but it sort of tells you what you're up against.
    https://www.phasetechnologies.com/pr...ect/enterprise
    A 230V 20hp model about $6000 and a 460V 20hp model nearly $7000 and both require 111A 230V input.
    Not cheap!!!
    Craig
    Aug 2005
    176
    Not cheap!!!
    Craig
    Didn’t want to go digital
  1. Replies: 3
    Last Post: 06-12-2022, 10:20 PM
  2. Rotary 3-phase converter
    By chuck767 in forum Phase Converters
    Last Post: 03-01-2018, 06:55 AM
  3. Rotary Phase Converter
    By moonman5 in forum Phase Converters
    Last Post: 03-20-2017, 06:13 PM
  4. Replies: 5
    Last Post: 04-05-2016, 03:14 AM
  5. Rotary converter
    By ozzie34231 in forum CNC Machine Related Electronics
    Last Post: 02-26-2011, 01:54 PM
