586,110 active members*
3,354 visitors online*
Results 1 to 6 of 6
    Oct 2005
    6
    Want to go faster
    I have 201's installed running tubocnc
    all works fine.
    I get cutterpaths from Unigraphics
    That all works fine.. Just slow
    50 Min to do a small part.
    Want to install G901,s
    Do I need 1 for each conrtroller?
    Is it as Simple as it Looks to go up to 10 times faster?
    Mar 2004
    1806
    doesitfloat,
    I am not sure you will be able to go faster just by adding this board. A lot depends on your mechanical setup and how much power your steppers have! Also, have you maxed out just how fast you can go in the configuration. Possibly you have your max speeds set to low? Or can you change the feed rate in your g-code program?
    I would look at the last thing first! If you are telling it to go slow in the g-code file, it will still go slow as you have to change your configuration for using the multiplyer board. Remember it you multiply steps by 10, you have to change your steps/unit by X/10 or it will move 10x as far as you command. Therefore, no speed change!
    Art
    AKA Country Bubba (Older Than Dirt)
    Oct 2005
    6
    OK let me specify where it is slow.
    Rapid movement Manual control of axis---fast
    Manual g-code if a circle----fast
    G code from UG feedrate at 30ipm and 10 ipm same and slow.
    The code I'm importing is primarly goto point x,y,z... Hundreds of lines of that.
    That is where it is slow.
    I have my accelerations set high( I think I'll check when I get home.)
    **thinking and typing out loud** Maybe my accelerations need to be set much higher because I'm telling to do so many small steps it never accelerates to the feed rate.
    Mar 2004
    1806
    OK, sounds like there is not a problem with the machine. You indicate it will move fast enough when doing fairly long moves. So possibly it is an acceleration factor or just plain the piece that you are working on. It sounds like the moves are short in nature? Not knowing what your working on, might it be possible to re-cam using a larger tool? It won't speed up the moves, but it will take more material per pass? Do a roughing pass with a "large" tool and then finish with a smaller tool to achieve the desired finish.
    Art
    Oct 2005
    6
    Went back and adjusted my accelerations.
    X and Y at 5000 and Z at 2000
    This doubled my old settings.
    Part machine time went from 49 min to 12 min.
    My test part is a bullet looking tube 1/2 " diameter by 2" long
    Mar 2004
    1806
    Sounds like you got it fixed. Good luck
    Art
  1. Girls have been faster learners - for 6 million years
    By WallCrawler in forum Community Club House
    Last Post: 07-21-2007, 05:18 AM
  2. Faster TM1?
    By drewmeister in forum Haas Mills
    Last Post: 02-21-2007, 05:27 PM
  3. Which is Best - Deeper Plunge/Faster Feed
    By bill south in forum MetalWork Discussion
    Last Post: 01-10-2007, 06:42 PM
  4. Why is speed faster than I set
    By monte55 in forum Machines running Mach Software
    Last Post: 11-04-2006, 05:48 PM
  5. Is the new server faster?
    By cncadmin in forum Polls
    Last Post: 03-14-2004, 02:03 AM
