587,047 active members*
2,987 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Wont let me draw Line or 3pt arc?
    Mar 2008
    454
    Question Wont let me draw Line or 3pt arc?
    Hello,
    I am using Solidworks 2020 and im having trouble drawing a curved line.
    So I have two points 30" apart... instead of a straight line between them, I want an arc with just a tiny deviation of 2mm at the center. (so the center point is 2mm off from the centerline).
    But it's acting like thats too small of a curve. If I use the line tool or 3-point-arc, I can draw exactly what I want, but when I click to confirm... it just disappears!
    I have gone to visual and performance settings and increased them to max, but no change.
    Why does the line disappear when I click to confirm?
    If I draw the exact same thing with a 10mm deviation, it works just fine.
    Mar 2008
    454
    Re: Wont let me draw Line or 3pt arc?
    ok I figured it out through trial and error.
    The radius using other methods was over 12,000 which I guess it just didnt like.
    Had to make a midway point between the ends and use the spline tool.
  1. SolidCAM line, arc, rapid G-code in every line
    By iIsTi91 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-13-2018, 06:56 AM
  2. Draw a line (VB.net 2005)
    By Switcher in forum Visual Basic
    Last Post: 02-13-2015, 08:17 AM
  3. newbie - cant draw a line
    By Fred Evans in forum Solidworks
    Last Post: 10-25-2011, 03:47 PM
  4. Replies: 5
    Last Post: 09-09-2009, 01:58 PM
