586,357 active members*
3,529 visitors online*
    Nov 2009
    14
    Question re: print / debug
    Is there a way to do either of the following:
    a) have a print or debug force a certain number of digits to be used? I have a series of print statements running that give me a status in the output screen with a time check - but the time, if it's a single digit, reads funny - 10:3:8 means 10:03:08.
    (print,|! Start Time: #<hh,0>:#<mm,0>:#<ss,0>)
    I experimented with the digits after the hh / mm / ss, but I'm having a difficult time discerning what they actually do and I can't find a reference that tells me.
    b) the other thing I tried was forcing mm / ss to be a text string using
    if [#<mm> LT 10] then (txt,mm,0#<mm>)
    but that didn't seem to do anything - I don't know if string concatenation is possible, but that might also solve this?
    Thanks!
    Mar 2017
    1312
    Re: Question re: print / debug
    I agree that time without leading zeros looks funny.
    Your solution with (txt will work after I fix IF..THEN statement (next version)
    Nov 2009
    14
    Okay - thank you. Is there a reference that explains the use of the digits after the parameter (example: #<hh,0>)?
    Thank you.
    Mar 2017
    1312
    I've added examples showing all current options:
    https://cnc.zone/gcode/comments/comment-print
  1. A print and cut question laserdraw
    By liltritter in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-23-2015, 07:50 AM
  2. Quick question on time to print
    By jake hoback in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-23-2014, 08:50 PM
  3. Question regarding best way to program part. have print attached.
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 02-05-2014, 05:39 PM
  4. still cant print and boolean question
    By erase42 in forum BobCad-Cam
    Last Post: 03-12-2006, 08:53 PM
