I currently drill and then use countersink bit to make holes for standard no6 or no 8 screws. I would like to buy one of those electric hydraulic punching machines and use a punch and die of 4.2 mm to make a hole and the countersink. There are some companies that will create a custom die punch, but I think I found one that looks exactly like what they suggest. The story is in the pictures.
Pic 1. my existing drill press drilled bard
Pic 2. punching machine
Pic 3. suggested punch / die
Pic 4. suggested punch / die
Pic 5. the punch die I want to buy (less expensive)
My question is - will it work?
I you can share how standard 90 brackets with countersink are made, why there isn't a common solution for this.
Best, Ariel
