587,427 active members*
3,198 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Machine base for manual bench mill: epoxy granite vs concrete
Results 1 to 20 of 24
    Jul 2018
    6470
    Re: Machine base for manual bench mill: epoxy granite vs concrete
    Hi Max - You seem to be fixated on a slab for some reason. Buy damped machine feet and that's money well spent. This slab/plinth thing is going in the wrong direction? If its a test case for machine parts maybe a good idea but in terms of machining benefit you won't get any. Re: inability to predict. With all of these materials nearly everyone is unable to predict. I do dynamic analysis for a couple of companies and I'm always telling them this is fuzzy stuff unless they commit to a serious materials testing program (elastic and sonic). Which they don't do due to $$$... so even us pros are guessing at some stuff... If you have simulation that does modal analysis it will calculate the critical (natural) vibration modes of your structure & parts. The next step is to add damping and unless you have real data on that for the material you/everyone is guessing...
    If you ran the monolithic slab you will see that its modes are well away from any of the machine modes. So the plinth is not doing anything to "absorb" vibes in regard to helping the machine quality of cut... The dampest solution is to make a box and fill it with sand. Any "solid" has quite a low damping ratio. This is explained in the Topic 14 article. But the load does not travel through your plinth. The machine loadpath is between the tool and the part (ie the machine) that's the path you need to investigate.
    So 1) define exactly what you are trying to achieve here? 2) if your doing something right the forum is very quiet, if your doing something wrong the noise is very load! Peter
    In regard to machine mounting there are two camps:
    1) The machine is mounted free on its own feet. This camp relies on the machine mass for dynamic stability. The machine does not accelerate fast enough (generate high enough inertia loads) to move the machine mass. The bigger the machine the more it moves into this territory. There are some mill makers for instance that expressly forbid machines to be connected to the floor, probably for thermal reasons. But there are other makers that recommend the machine is bolted to the floor for better stiffness and stability. My 300kg router if I ramp up the accles will dance easily...
    2) Bolt the machine to the earth. This effectively makes your machine infinite mass. Some makers recommend this and provide machine feet that allow this. This solves the dancing machine issue if the machine is light and has high accel potential. This is particular to fast small/medium machines and most robots are screwed to the planet as they move very fast and are very light... Keep at it. Peter
    Jul 2023
    8
    What is it that I'm trying to achieve is actualy simple: I just want to build a cabinet to put my new bench mill ! ;-)
    The concrete slab is first and foremost a solution to the problem of needing a top plate on the cabinet to rest the mill on !
    I thought that the slab could have a secondary benefit of damping.
    Now thanks to you and Craig, I know the slab won't provide much damping, and that the need for it isn't much there to begin with.
    But I still need a plate for my cabinet, I excluded wood, because it becomes a mess with the oils, coolant, etc, and there can be occasional sparkles, etc.
    Given that a concrete slab is cheaper than a metal plate, I think I will go with the steel reinforced slab desing, because it's a no brainer to design and to get done.
    It will be more or less like this : https://www.youtube.com/watch?v=ZsUkNUGpRaE
    Thanks again for the great advices !
  1. Replies: 5052
    Last Post: 02-08-2024, 12:42 AM
  2. Replies: 2
    Last Post: 12-28-2020, 08:04 AM
  3. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  4. Epoxy granite or UHPFRC Concrete 5 axis CNC
    By Halbmond in forum Epoxy Granite
    Last Post: 11-07-2018, 01:04 PM
  5. Custom made precision mill with epoxy-granite base
    By circaeng in forum Epoxy Granite
    Last Post: 01-26-2012, 10:05 PM
