586,602 active members*
3,433 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Gifted new coolant system - help get it working, please
    Aug 2009
    9
    I have a manual Bridgeport Mill. I was gifted a new coolant system which has a PLC solenoid valve. I can hook up the air lines and all. However, might any of you have any ideas on if, and how, to power up the solenoid to get it working?
    I'm an old hobbyist with to much time on my hands! Any help appreciated!
    Attachment 504248Attachment 504250Attachment 504252
    Dec 2005
    595
    Re: Coolant pump for benchtop mill
    You might want to ask that in the Bridgeport Mill forum. This forum is for benchtop machines.
    Mark
    Aug 2009
    9
    Ok, Thanks!
    Dec 2008
    3111
    Re: Gifted new coolant system - help get it working, please
    Only a suggestion.
    Have to power supplied from the spindle ON circuit, and an inline ON/OFF manual switch to the relay.
    Spindle ON, power supplied to manual switch. Coolant can be turned ON/OFF
    Spindle OFF, coolant is OFF
    Aug 2009
    9
    Superman, Thanks for the suggestion. I decided to by pass the solenoid and just use a manual valve. Thanks!
    Bob
  1. Replies: 0
    Last Post: 01-04-2024, 10:48 PM
  2. Coolant pump not working
    By Tbkahuna in forum Tormach Personal CNC Mill
    Last Post: 02-17-2011, 04:21 AM
  3. Gifted Lath II / Worth Repairing ?
    By Jeff Davis in forum Taig Mills / Lathes
    Last Post: 11-23-2009, 09:18 PM
  4. coolant not working after upgrade
    By mark c in forum Machines running Mach Software
    Last Post: 12-03-2006, 02:43 PM
  5. coolant not working after upgrade
    By mark c in forum Mach Software (ArtSoft software)
    Last Post: 11-27-2006, 01:48 AM
