586,808 active members*
7,971 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > What software do I need to create these lips??
Hybrid View
    Apr 2024
    HI CNC Legends,
    I've seen folks selling DXF files on Etsy like the below and would like to learn how these are created as I have some ideas of my own I would like to make for personal use. Can anyone please help with how and what software I would need to create a file I could cut out on my hobby cnc.
    Here is the link to the item mentioned above:
    https://www.etsy.com/au/listing/1403...BoC9kYQAvD_BwE
    Any help would be much appreciated.
    Apr 2004
    5742
    Re: What software do I need to create these lips??
    First you'd make a 3D model of the lips. Then you'd intersect it with a series of evenly-spaced planes, generate curves at the intersections and save them as DXF. Then you'd create toolpaths from the DXF curves in a CAM program and nest them to cut them most efficiently out of a sheet of material. You could do the CAD work with MOI (Moment of Inspiration) https://computersculpture.com/moi/ and the CAM part with DeskProto. https://computersculpture.com/deskproto . Of course, there are lots of other programs that could also do this.
    Andrew Werby
    Website
    Apr 2022
    137
    You can do slicing in Vectric and create a tool path or save in DFX.
