586,430 active members*
3,915 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > What is the advantage of adding your specific Machine Type in the library
    May 2013
    170
    I have been using fusion 360 cam for my Haas DM-2 for years and just discovered that I never went through the process of setting up that specific machine in the machine configeration section in.
    I do have the correct post processor for my Pre NG controller.
    Just wondering if there are any huge advantage to going through the process?
    Kent
    Dec 2008
    3111
    Re: What is the advantage of adding your specific Machine Type in the library
    Probably none... if you have only one machine.
    If you had more than one, then you would need to select what machine you are writing code for.
    May 2013
    170
    Quote Originally Posted by Superman View Post
    Thanks for your response.... The reason I asked was things have been working so well with my current process and post processor.... and I could envision spending hours and hours cleaning up the mess that I found myself in changing things up.
    Thanks again...
    Kent
  1. Problem with specific type og G-Code system
    By mehrzadja in forum Milling
    Last Post: 09-28-2020, 06:52 PM
  2. Replies: 32
    Last Post: 02-07-2017, 09:10 PM
  3. Replies: 20
    Last Post: 07-21-2016, 06:28 PM
  4. adding a tool to the Library
    By ArtistInFla in forum BobCad-Cam
    Last Post: 03-29-2010, 09:13 AM
  5. Trying to find a specific type of cutter
    By Airassault in forum Want To Buy...Need help!
    Last Post: 03-20-2009, 10:16 PM
