586,350 active members*
3,222 visitors online*
Results 1 to 1 of 1
    May 2023
    20
    5.1 gearbox alternative?!
    Hi, I have a ez-router scorpion cnc that has 5.1 Cuken planetary gearbox. I’m wondering if there are any alternatives that may work for me? To order one from ez-router is $1000. Ordering direct from the company in china is $189 + freight but it’s very hard to get ahold of them as you can imagine. Here are the specs of the gearbox http://www.precisiongearbox.com/html_products/PF80-SERIES-PRECISION-GEARBOX-SERVO-SPEED-REDUCER-133.html
    Jun 2005
    1730
    Re: 5.1 gearbox alternative?!l
    Quote Originally Posted by davidmadewood View Post
    Hi, I have a ez-router scorpion cnc that has 5.1 Cuken planetary gearbox. I’m wondering if there are any alternatives that may work for me? To order one from ez-router is $1000. Ordering direct from the company in china is $189 + freight but it’s very hard to get ahold of them as you can imagine. Here are the specs of the gearbox http://www.precisiongearbox.com/html...DUCER-133.html
    The planetary gear head has very little backlash. You could go with a belt drive with two different pulleys to get the reduction. The Chinese gear head for $189 is cheap but you need to check backlash specs. The other option is a used planetary gear head from eBay, look for HD harmonic drive
    Russ
  1. Excello 602 (605) z axis gearbox oil + main gearbox gaskets
    By dholzric in forum Uncategorised MetalWorking Machines
    Last Post: 03-27-2018, 10:08 PM
  2. Comparison questions, BMDC3 vs. BMDC4, gearbox vs no gearbox
    By nlh in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2016, 06:37 AM
  3. Do I need a gearbox?
    By Erant in forum Servo Motors / Drives
    Last Post: 09-06-2015, 01:15 AM
  4. Gearbox????
    By Burnit0017 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-21-2011, 11:49 PM
  5. VF-6 50 Gearbox
    By BJSwart in forum Haas Mills
    Last Post: 03-10-2009, 03:01 PM
