586,350 active members*
3,265 visitors online*
    May 2023
    6
    AXYZ 4008 Router
    I have a AXYZ 4008 ATC CNC Router which requires a major service. During an audit we found the linear bearings grease nipples are not easily accessible and to remove the linear bearings is a big exercise. I require the all the linear bearing part numbers.
    If anyone could be kind to assist with any technical information regarding servicing of the machine and supply me with a BOM (Build of material) we would greatly appreciate it.
    1228
    Re: AXYZ 4008 Router
    AXYZ will supply a very slim nozzle that fits a standard grease gun.It isn't particularly cheap,but it makes the job quite easy.
    May 2023
    6
    Hi Routalot
    Thank you for the info. I'm based in Mauritius and have mailed AXYZ but haven't had any response.
    I also require the linear bearing part numbers as accessibility to the mounting bolts is a challenge as there needs to be somewhat to dismantle to reach the bolts.
    Thx
    1228
    Have you tried the UK branch of AXYZ?They will be several time zones closer,which helps with the overlap of the working day.These pages may be of interest to you:
    https://uk.cncshop.com/collections/a...ew=bc-original
    https://uk.cncshop.com/collections/a...32399948415060
