586,403 active members*
2,293 visitors online*
    Apr 2024
    Converting a Cantech L20 laser engraver to a CNC
    How crazy of project is it, and is it possible to convert a Camtech L20 laser engraver to a CNC? I have had an experienced CNC operator tell me the gantry would not be able to deal with the vibration from the spindle due to lack of mass. Others have said it can be done. I have the option to get the machine for an extremely reasonable price. Worth going down this road? I have a very short window to jump on purchasing the machine, so I am trying to get as much info as possible as quickly as I can. I'm a woodworker, computer savvy, no CNC experience.
    Looking forward to hearing what the collective has to say.
    Nov 2008
    643
    Re: Converting a Cantech L20 laser engraver to a CNC
    I don’t know the machine however lasers are usually higher speed, lighter duty steppers, belt driven with much lighter duty components (and drivers) because there is no load on the lens assembly. CNC routers are have similar speeds for rapid moves but, screw driven and heavy duty due to high cutting loads.
    Laser software and the laser controller is also not designed for wood cutting.
    I would think you could cut wood but only at very low feed rates. I would use the laser as intended. A laser cutter is a very versatile tool with a lot of capabilities.
    Apr 2024
    From what I have been told, the Cam Tech machine was built to be capable of being used as a CNC. Chain driven, not belt, and heavier duty motors. I know they are not a common machine out in the market place, but there are some users here on the forum. Hoping some people with experience on the machine can share some insight.
  1. Advice needed converting old Vision engraver for CNC use
    By electro5 in forum DIY CNC Router Table Machines
    Last Post: 03-14-2024, 05:04 PM
  2. DIY Converting old engraver to full CNC router
    By katemonster in forum DIY CNC Router Table Machines
    Last Post: 08-13-2019, 01:16 AM
  3. Converting Shark Pro CNC router to laser engraver
    By Pazzoom in forum Engraving Machines
    Last Post: 02-27-2012, 04:58 PM
  4. CAMTECH L20 LAZER ENGRAVER
    By elganb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-13-2011, 06:39 PM
  5. Converting a cheap printer to a laser engraver for wood
    By thistleguy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-22-2009, 12:46 PM
