586,432 active members*
4,103 visitors online*
    Jul 2018
    7
    Panelmate Touch Screen
    I have an 18.5 inch wide Panelmate touch screen installed on a fiber laser machine. touch is not working properly and it can't be calibrated. When I try to open calibration interface, it gives an error message that some files are missing. I tried to uninstall touch software and reinstall it again, but it gives me a message that another version is installed even though I uninstalled it. I tried to install some other touch software but it didn't work. anybody knows how to fix this problem or can give me some guidance?
    Mar 2015
    410
    Re: Panelmate Touch Screen
    I asume you have that touch panel installed on a windows machine.
    When you uninstall the touch screeen, windows keeps the drivers on the machine. It only removes the installed touch screen.
    If you reboot windows and plugin your touch screen, it will be recognized and Windows will install the drivers. If you Google, you will find a lot of answers how to uninstall a driver. I do this by selecting the installed device in windows hardware and remove the device. Windows will than ask to remove the drivers as well.
    Next step is to disconnect the device, install the right drivers and than connect the device.
    This explains how it is done, It works in all windows versions.
    https://www.elevenforum.com/t/how-do...program.18232/
  1. TOUCH SCREEN
    By marek.m in forum CNC Machine Related Electronics
    Last Post: 05-25-2017, 07:29 PM
  2. Acromatic 950 Touch Screen Retrofit - No Response From Touch Screen
    By csokoll in forum Controller & Computer Solutions
    Last Post: 05-27-2014, 09:41 PM
  3. New Screen set for my touch screen
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 08-17-2010, 01:37 PM
  4. Replies: 6
    Last Post: 07-13-2008, 11:28 PM
  5. anyone use a touch screen?
    By jderou in forum Screen Layouts, Post Processors & Misc
    Last Post: 09-02-2005, 12:09 AM
