586,974 active members*
3,563 visitors online*
Results 421 to 440 of 815
Threaded View
    May 2006
    184
    Rotary table indexer
    Hi, I built this last year but thought it may be of some use to others...
    It's basically a stand alone PIC based indexer for use with rotary tables, it's pretty cheap - can be put together for 50ukp or so, it outputs step and direction to a suitable controller (I used a cheap controller off eBay - see internal.jpg in pics folder).
    I built it to save using index plates and because I don't want to use a fully blown computer for simple indexing.
    Written in HiTech C and based on a PIC18F452, source is included for the curious amongst you - please read the document 'legal and instructions.doc' file.
    Electronics folder contains a pcb layout and overlay as .bmp files - also a .LYT file for use with Proteus, partslist and circuit diagram.
    Pictures folder contains a few images of the completed controller.
    Source contains the C files.
    In the root there's a keypad template that can be used with the recommended keypad, use instructions and the final .HEX file to program the PIC with.
    Hope it's of some use!
    Steve.
    P.S Should be RotaryTableIndexer.zip attached to this thread
    Attached Files Attached Files
  1. Stand alone rotary table indexer.
    By kwackers in forum PIC Programing / Design
    Last Post: 01-29-2023, 03:01 PM
  2. CNC Rotary Indexer/Table
    By desman in forum Commercial CNC Wood Routers
    Last Post: 08-11-2015, 03:32 PM
  3. 4th Axis CNC Rotary Indexer Table Plans
    By Modular CNC in forum News Announcements
    Last Post: 05-11-2011, 07:55 PM
  4. Manual indexer-rotary table vertical
    By silverfoxx03 in forum Want To Buy...Need help!
    Last Post: 02-18-2011, 09:04 PM
