586,071 active members*
3,799 visitors online*
Results 1 to 7 of 7
    Sep 2007
    122
    Unhappy Mitsubishi Meldas L3
    I am trying to get a Leadwell GTC-20 Lathe going. The tech guy from Mitsubishi was a big help but I had to "re-boot" initialize the control. I lost ALL of my parameters and am looking for someone to help me. Is there anyone out there who can send me the parameters from their machine? I called the former owner and they did not have them backed-up.
    This is a start-up of a used machine. I have never had a Mitsubishi control before and it is not obvious where to back-up the parameters in the screen menu.
    Thanks for reading.
    This is my message to Leadwell:
    I am trying to fix a Leadwell Lathe.
    The guy we're buying it from had an issue with the screen not coming on at all and called in a service guy. He rebooted the system.
    The lathe now comes up with the screen OK but the thing will not home. The turret is off location but seems to work fine. The chuck works fine. The Tailstock works fine. The machine shows no alarms but will not jog in MPG mode.
    All of the programs are gone. The relay#11 is blinking to indicate an alarm but the alarm page does not show anything. There was a coolant alarm but I filled it up and it went away.
    Can you point me in the right direction on how to make this thing move in X or Z?
    LEADWELL SN L29302015
    320162 UNITJ
    Mitsubishi Meldas L3 Controller
    Main BND-271W000-B2 SV1 BND-507W000-A7
    MACRO 261W610-B0 SV2 507W000-A7
    PLCv GTCW2A3-1
    BOAD SP1 550W004-C3
    Sep 2007
    122
    Formating the L3
    Formatting should not do anything to your parameters, but make sure you have a back up incase. If you enter the parameters through the RS232 port, make sure you write down the I/O parameter settings. These will have to be set first before you can load parameters into the machine. But, again nothing should happen to them when reformatting. Below is the format procedure from the book. The fixed P parameter is in the Machine parameter area ((1001) ( ) (M)). Program delete is in the Data IN/OUT area (Erase soft key). The entry of standard fixed cycles is done on the Data IN/OUT area (INPUT soft key). Make sure you push the Input key after each step.
    1. #6 fix_p (1) INPUT >>>>>>>>>>>>>>>>>Machine parameters
    2. #( ) Data ( FORMAT) INPUT>>>>>>Data IN/OUT Erase
    3. #( 4) Data ( ) INPUT>>>>>>>Data IN/OUT Input
    4. #6 fix_p (0) INPUT>>>>>>>>>>>>>>>>>>Machine parameters
    Cycle Power
    Feb 2008
    5
    Please help me. How to re-boot initialize the control Mitsubishi meldas L3?
    Thank you
    24221
    You can I believe still get the L3 manuals off the MEAU site.
    I think the T3 is the same.
    Here is a couple of PFD's.
    Al.
    Attached Files Attached Files
    Albert E.
    Feb 2008
    5
    Thank you for your help.Meldas M3/L3 series using MC 161 CPU card and MC 713 A CRT card. Are they have equal method with T3 Series that used different card.?
    sorry, I have found nothing in MEAU site.
    Thank you
    Jul 2022
    Re: Mitsubishi Meldas L3
    We have purchased one Leadwell CNC Lathe GTC -20 Sr.No. L29303009 YOM. NOV 1994 MODEL MELDAS -L3 MFG NO. C3715870132 from the US.
    WE have facing some problem in this machine. The screen is blank. No message showing. WE wanted the solution to fix this problem.
    We need this machine service manual, Electrical manual as well as meldas - L3 manual.
    Jul 2022
  1. Mitsubishi Meldas 300-V
    By firestaromega in forum Computers / Desktops / Networking
    Last Post: 10-03-2023, 08:00 AM
  2. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2022, 07:12 AM
  3. Mitsubishi Meldas 60S
    By BKCOM in forum Mitsubishi controls
    Last Post: 11-28-2016, 03:59 PM
  4. Mitsubishi M-V60C w/c MELDAS 300M
    By Tulak in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2007, 04:03 AM
  5. ask for help about connecting pc to mitsubishi meldas 50s
    By samhai in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-16-2007, 09:39 PM
