586,071 active members*
3,840 visitors online*
    Feb 2006
    1260
    Can Not get any movement from steppers.
    My system is basically a PlaxPack 1A, Purchased from CandCNC: http://www.candcnc.com/PlasmaPakPriceChart.htm
    I have everything hooked up, Mach3 installed, Support disk loaded, and
    the plug in for the MPG101B pendant installed in mach.
    I have installed the 2nd. parallel card, enabled port 2 made sure port address is correct & is set to LPT2. I have enabled all the OEM TRIG #'s as instructed in the MPG101B setup manual. The encoder/MPG(s) disabled.
    I have calculated for reduction ratios etc. & entered the in motor tuning section.
    Everything looks correct. There are no lighted LED(s) on the I/O card.
    As per the manual most of the LEDs are lit on the raw ports. I can get
    movement of the DRO(s) by using the arrow keys on the keyboard or the joy stick in jog mode & it will let me toggle between each axis. Charge pump lights on the THC. The relays will cycle & operate the solenoids on my table when the mist and or the flood buttons are toggled on & off, but no movement, hum buzz or shutter on any of the steppers.
    I have turned everything off, checked all the DB cables to be sure they have seated together & are connected to the right ports. Powered everything back up but still same problem.
    Below is a screen shot of the diagnostics page in Mach.
    Please help anyone.
    If it works.....Don't fix it!
    May 2006
    179
    Did you get it running?
    Feb 2006
    1260
    Yes have been cutting metal for well over a year now.
  1. New W.XP and Mach 2.48 no movement
    By hugo carradini in forum Machines running Mach Software
    Last Post: 10-14-2007, 05:44 PM
  2. No Movement
    By wishmasterg in forum Mach Mill
    Last Post: 02-15-2007, 01:39 AM
  3. No Movement of steppers help please
    By rally.sport in forum Machines running Mach Software
    Last Post: 12-22-2006, 04:05 PM
  4. Erratic movement on steppers - need help
    By maxxgraphix in forum CNC Machine Related Electronics
    Last Post: 06-12-2005, 01:43 PM
  5. Help! ...no drive movement
    By CRFultz in forum CNC Machine Related Electronics
    Last Post: 01-22-2005, 02:30 AM
