586,102 active members*
2,555 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > frustration....plasma cuts off during cuts any ideas?
    Feb 2007
    Hi Everyone,
    I have had a dyna cnc table with mach3 controller up and running for about 4 months. Hi have a thermal dynamics 101. Recently while cutting the torch will shut off. At first it was once in a while, now it will only cut about 2-3 inches and shut off. it is worse on thinner material. Any thoughts? I am sure it is the plasma cutter. I have changed all consumables, checked for water in lines, checked pressure and adjusted amperage settings like a villian but it still is continuing to do it.
    the operation manual and the maintainence manual both point to overheating, but it will do it just 30 seconds into being turned on. The fan is working and the kicker is that I can use the hand torch without a single problem....
    Do y'all have any thoughts?
    Jan 2007
    599
    I know you checked for pressure, but it could be that your losing pressure while cutting.
    Oct 2005
    1238
    Quote Originally Posted by gpnjuice View Post
    Hi Everyone,
    It might be a bad ground if the work clamp is not attached directly to the workpiece.
    The thinner material is often too light weight to pick up proper grounding from the support slats.
  1. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
  2. My new TM-1 cuts!!!!!!!!!!!!!
    By blackhollowmfg in forum Waterjet General Topics
    Last Post: 03-16-2007, 02:24 PM
  3. New plasma cutter ( Even cuts concrete )
    By ynneb in forum Waterjet General Topics
    Last Post: 01-20-2007, 08:54 PM
  4. First cuts
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 10-27-2006, 05:17 PM
  5. First cuts
    By no priors in forum MetalWork Discussion
    Last Post: 08-21-2006, 04:03 PM
