586,094 active members*
4,083 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > HF 44991 X2 Mini Mill Motor Wiring?
Results 1 to 6 of 6
    Hello Guy's
    I just assembled my HF 44991 X2 mill to a CNC version. I was wondering if anyone knows the motor wiring inside the box for the speed control? I misplaced the notes I had on that one. A picture of inside that box would be perfect.
    Bill
    Bill
    Jul 2004
    218
    EDITED:
    I'll post a photo in a few minutes.
    Jul 2004
    218
    Ok,
    All three of the blue wires go to the Pot, #1 being on the slow end and #3 being the fastest.
    Wire #5 goes to the Amber Fault Light
    Wire #4 goes to the lower fuse connector
    - Upper fuse connector goes to Lower Left E-Stop Connector
    Wire #3 goes to upper left E-Stop Connector
    Connectors:
    White to White
    Green to Green
    Black to Black
    As for Wire #1 & 2, I'm not sure, although I believe that they both go to the E-Stop so I suppose it doesn't matter.
    Hope that helped. It's a pain in the rear. I lengthened my wires and disconnected my speed control box from the mill all together. When it was over and reconnected I think the whole ordeal took a couple of weeks off my life.
    Hi Dang,
    Thanks, If you could ... please check these wires that connect to each other with plugs. I marked their location in your picture.
    Bill
    Bill
    Jul 2004
    218
    Those would be the wires marked #1 & 2 that connect from the board, directly to the motor. I told ya, this is difficult. Last time I thought they connected to the E-Stop. Anyway, they should connect to the similarly colored wires with the sleeved male/female connectors and just run right out the other, skinnier tube to the motor.
    I hope that was correct.
    *If the wires aren't similarly colored, then hit them with a multimeter to determine which of them is Negative or Positive.
    #1 is negative.
    #2 is positive.
    The other, (green) is ground.
    Jul 2004
    218
    You may wanna get a bunch of spare fuses when you 1st put charge back through the system.
  1. Mini Mill Motor Flange type
    By PIngels in forum Benchtop Machines
    Last Post: 04-28-2006, 03:32 PM
  2. Mini Mill Motor Size
    By jjwl89 in forum Benchtop Machines
    Last Post: 08-10-2005, 09:24 PM
  3. HarborFreight Mill 44991
    By Brass_Machine in forum Benchtop Machines
    Last Post: 04-13-2005, 01:24 AM
  4. It's ON! (HF mini-mill #44991)
    By Nonoriginal in forum Vertical Mill, Lathe Project Log
    Last Post: 03-20-2005, 03:16 AM
  5. Mini Mill Motor Amperage
    By jjwl89 in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2004, 12:56 AM
