587,012 active members*
3,490 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > Help: Casting Aluminium
Results 1 to 7 of 7
    Aug 2006
    161
    Hey Guys
    I have quite a bit of aluminium left over as offcuts from my cnc machine.
    I am interested in casting and would like some advice
    I presume Sand casting is the easiest for fairly simple parts? (bars etc)
    Question is do I go for electric or coal powered. Also does anyone have any links to plans to build a furnace?
    Also where to get the insulation etc?
    Any one else in the uk doing their own casting?
    DJH
    Apr 2005
    1778
    I would recommend either electric or propane. I personally use propane. It gives reasonably quick melts with no ashes to dispose. I have plans for an electric furnace but it seemed like a lot more work than my propane furnace.
    Sorry I can't help with resources in UK but my burner is basically made from pipe fittings. It uses a TWECO fitting for the burner jet but you can make one from a brass pipe plug. The furnace shell is made from rolled sheet metal. The hardest thing to find may be the insulating material for the furnace.
    Take a look at the propane furnace on my website. Also take a look at the furnaces on Cameron McKeown's site. http://home.iprimus.com.au/cmckeown/foundry.htm
    Here is a link to plans for a small electric furnace. http://www.dansworkshop.com/Aluminum%20Foundry.shtml
    There is also a Yahoo "HomeFoundry" group.
    Alan
    Aug 2006
    161
    Thats great, I will have a look into the info you gave
    DJH
    Feb 2006
    210
    Google Lindsay Publications and then get Dave Gingery's Foundry book. It's the best place to start.
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Nov 2007
    17
    furnice
    hi mike here i have a foundry.
    the lindsey books are real good they'll tell you how to mix the sand up and to make flask to hold the sand,ect.
    i have a pic of my furnaces i made if i new how to upload the pic i would show it to you
    ps i love this site learned so much allready let me know
    2010
    I stacked fire brick into a small cube less the top then welded an angle iron frame to hold it together. Two more bricks provide a top, a small gap between them provide an adjustable vent hole.
    I used my mill and a hole saw to cut a hole in one of the brick to go into one side, this sized just right to insert the snout of a propane weed burner.
    Voilla! Instant furnace, a cast iron pot provides a crucible. Long handle iron spoon for scooping dross, fine grain sand and an assortment of buckets provide molds for my foam patterns.
    Cost: less than $50.00 total.
    Time invested: one Saturday afternoon.
    Oct 2004
    118
    I learned some about casting hereBackyard metal casting
    Noooo not another hobby
  1. Aluminium Die Casting Mould
    By ahmedrehan in forum Moldmaking
    Last Post: 02-02-2009, 02:51 PM
  2. My first casting
    By tool_man in forum Casting Metals
    Last Post: 03-29-2007, 05:28 AM
  3. Magnesium Casting
    By MXMFG in forum Casting Metals
    Last Post: 01-23-2007, 07:16 PM
  4. Magnesium Casting
    Last Post: 01-04-2007, 03:07 AM
  5. STL and casting
    By Jcadwell in forum MetalWork Discussion
    Last Post: 05-15-2006, 10:01 PM
