Hello~
I just got my mill early last week... I haven't had much time until now to start cleaning it..
So, I downloaded the "Introduction_to_your_machine.pdf"... and followed the instructions... upto page 3... "Using your superhuman strenght..."
The motor mounting plate won't slide away from the bed... The dowel pins must be in too tight... When I pull on the table, the stepper and screw spins...
If remove the stepper and then the bearing... I don't think it will slide off to the left as it will catch on the bottom... And it wornt slide of the to the left... I guess my only choice is to release the preload on the bearing and then slide the table off the right side...
Any suggestions ??
Michael
