Have created a nema 23 motor mount in pdf format.
To use it just glue it to a peice of wood/aluminium and drill out the holes needed. Ive added dimensions but as Im in the UK these are in cm.
Thank you i think i will use this !
My build log: http://www.mycncuk.com/forums/showthread.php?t=7
Thank you!
Here is another version, in inches and mm.
John
I posted another on my lathe conversion. I have used this on my lathe and my mini-mill and the same standoff pattern on my router but with Nema34 motors.
Alan
