586,103 active members*
3,367 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Finish Cutting pass.
    Mar 2007
    21
    I am using Mastercam 9, Sherline Mill. 1/8 ball cutter.
    So I am cutting a Rough cavity (.9 deep ) at .030 thou spacing, when I pass with a finishing pass it goes directly to the bottom of the cavity, my cutter binds on the cavity wall because it’s a ball cutter, and the shank, which has no flutes binds. I can think of many work arounds like manual editing, but maybe someone has experienced this and knows how to fix it. I use a ball cutter because the cavity is dish shaped, like a tire track in the mud.
    Jun 2007
    3757
    Smile
    Quote Originally Posted by Greg Maxwell View Post
    Try setting the cutter size very slightly larger, so that the cutter stays away from the wall by the radiuis of this extra amount. You may have to fudge the cutter depth too, as it may try to miss the bottom as well.
    After looking at MC9, try changing the arbor diameter in the tool setup. Make it closely match what your cutter shape is.
    I believe the arbor part will be non cutting.
    Mar 2007
    21
    Good Ideas, I will try them. Thanks.
  1. Would you pass your knowledge on for free?
    By ImanCarrot in forum Polls
    Last Post: 12-29-2015, 02:41 PM
  2. Replies: 13
    Last Post: 01-10-2006, 03:22 PM
  3. Can I run axes at different ipm on the same pass?
    By yorttroy in forum DIY CNC Router Table Machines
    Last Post: 01-04-2006, 07:34 PM
  4. the finishing pass
    By inthedark in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2004, 12:58 AM
