Hi.
I am the stage where I want to mount the HobbyCNCPro into its own enclosure.
My question is : When mounting the board,do I bolt it to the enclosure with metal bolts or do I use plastic spacers?
I am going to use the controller for a CNC plasma table and all of the components needs to be grounded properly.
In other words will it be save to ground the board to the enclosure and then connect to enclosure to a proper ground connection? (Not the normal earth)
Any info would be welcomed.
Thanks.
Bert.
