586,096 active members*
3,762 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How to figure out what servo size you need
Results 1 to 9 of 9
    Jun 2004
    201
    When searching for servos there are so many options. I have a Sieg X3 and I have no idea what size servo to get for it. Is there a formula or a chart some where?
    24221
    You can find the free Kollmorgen s/w plus other help at this site.
    http://www.electromate.com/technical...morgansoftware
    Al
    Albert E.
    Jun 2004
    201
    Boy thats a complex program.
    Jun 2004
    201
    Does anyone have a suggestion as to what size servos the Sieg X3 would need.
    The mill is currently lead screws, but ball screws will be added.
    all screws are 5/8
    The Z screw is 26" with gas piston support.
    X and Y are 12" and 29"
    4th axis turntable is 6"
    What I need to know is should I be looking for 200 oz 400 oz etc.
    Should I look for only nema 23 or 34 frame sizes?
    max min volts amps
    Min RPM
    Should I order some of those US digital optical encoders?
    I just dont know what would be under power and what would be over kill.
    Jun 2004
    201
    Anyone?
    332
    What did the Kollmorgan software suggest?
    Jun 2004
    201
    I couldnt understand how it worked
    Jul 2003
    167
    Look at www.homecnc.info, a little larger mill with 430 oz-in servos.
    Look at camtronics, http://www.seanet.com/%7Edmauch/ which sells mill retrofits. Maybe he would have a suggestion.
    I tried the software. It is not so difficult to use, however supplying reasonable values is the hardest. Try the leadscrew mechanism and supply the values.
    Apr 2004
    439
  1. Using surplus servo motors as spindle drive
    By Swede in forum Servo Motors / Drives
    Last Post: 03-16-2008, 02:05 PM
  2. Servo Motor Running away.
    By murphy625 in forum CamSoft Products
    Last Post: 02-27-2005, 08:08 PM
  3. 2nd Generation DeskCNC servo driver released
    By imserv in forum News Announcements
    Last Post: 11-25-2004, 01:22 AM
  4. How to figure needed stepper motor size?
    By Hack in forum CNC Machine Related Electronics
    Last Post: 07-19-2004, 09:43 PM
  5. steppers or servo drives
    By mmjpotter in forum Gecko Drives
    Last Post: 03-30-2004, 09:56 PM
