586,103 active members*
3,402 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > spline groves milling with 88hs control
Results 1 to 11 of 11
    Nov 2007
    8
    Need help. just received 1986 fadal with 88hs control
    and need some help/info in regards to control abilities.
    All our machinery is equipped with Siemens 840D and
    we cut cpline groves on 1/4 plates. does anybody know if 88hs
    control can perform this and how.
    Regards,
    Dan
    156
    What type of tool are you using? And what is the spline specification? What RPM and feed rates are you using on the machines with the Siemens control? 1/4 plates? what type of material (steel) are they?
    Safety - Quality - Production.
    Nov 2007
    8
    Sorry,
    but rpm, tool type and mat/l are not relevant to my question but to satisfy you curiosity it is inconel, 2mm end mill, an a hole lot of RPM.
    Please,
    i still need info if this control can translate points into spline path.
    Regards,
    Dan
    Mar 2006
    2712
    Dan, You referring to a curved line spline (first guess) or a shaft with grooves (second guess) or a hole with internal grooves that slide over a grooved shaft (third guess)?
    DZASTR
    Nov 2007
    8
    spline
    Richard, thanks for your reply,
    it is curved line/spline,
    here is scenario to further clarify:
    vertical boring mill,
    4' x 4' x .25" thick plate on the table,
    (2D machining,)
    small end mill (2mm),
    need to cut 30 spaced groves x 1.0mm deep
    on the same plate but not in the strait line.
    They are all curved lines or splines and all with there respective and
    different curvatures.
    Sorry for not clarifying more in the first place, i hope this give you enough
    info.
    Regards,
    Dan
    Nov 2007
    8
    Richard,
    4' x 4' x .25" thick plate,
    (2D machining),
    small end mill,
    need to cut 30 spaced groves on the
    Sorry for not clarifying earlier i thought
    1/4 plate was enough.
    I hope this info is enough.
    Best Regards,
    Dan
    Nov 2007
    8
    enybody please
    156
    The Fadal control does not have a splining utilty built in. You need a CAM package that can turn the points into circles and lines, and postprocess into G2, G3, G1 code for the control.
    Dec 2007
    32
    what cad-cam software do you have
    you never know what you can do, until you have to undo something you have done!
    Jan 2004
    3154
    What Paul said.
    It will run whatever G code you put in it.
    Get CAM software.
    www.integratedmechanical.ca
    156
    On my TI-86 I have a cubic spline program. Which is non-graphical and can be used to spline data points along one axis (x). Not as sophicated as found in modern CAM software.
    I have used programs like it in the past to find missing data points on a curve.
    I use a CAM program at work, when necessary.
  1. Maximum Memory, 88, 88hs
    By DEAN in forum Fadal
    Last Post: 12-01-2007, 07:41 PM
  2. Fadal 88HS problem
    By rai in forum Fadal
    Last Post: 09-01-2007, 04:36 PM
  3. Going from 88 to 88hs
    By carbidecraters in forum Fadal
    Last Post: 07-03-2007, 02:40 PM
  4. DNC to 88HS
    By stealth03ss in forum Fadal
    Last Post: 04-19-2006, 02:01 PM
  5. Jasnac MX1 Control Help! Mitsui Seiki Cnc Milling.
    By le_hungvn in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-30-2005, 02:25 PM
