586,655 active members*
4,583 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Dxf drawings cleanup
Results 1 to 11 of 11
    Jul 2006
    55
    Hey dudes
    Got some dxf files dowloaded from the net of some model airplanes that I would like to cut on my cnc using Mach3 and LazyCam
    The problrm is that when i load them the curves consist of a lot of small lines.
    So my toolpath is kinda "bumpy".....
    Are there any easy way to join these lines into a continious line.
    The join function doesnt work very well.
    Could any of you cad guys please take a look at the attatched file for me, and see if there are any hope?
    (the file is a dwg due to upload size, but need output as dxf)
    95% of all downloaded files appear the same way
    Thanx in advance
    Best reg
    Cory
    Attached Files Attached Files
    There's no easy way, but I'd do it one of two ways.
    Trace it with polyline arcs. By typing "a" during the polyline command, you can trace it with a series of tangent arcs by snapping to the existing lines.
    I'd probably do it this way, though. Trace it with splines, snapping to a few existing points, and then carefully moving the points of the spline to fine tune the shape. Then use a spline to polyline conversion tool, or save as v12 .dxf to convert to ploylines. The conversion tools give you more control. You'll still have the shape be made up of straight segments, but it should be much smoother.
    Nov 2004
    436
    dxf
    I used rhino to split and rebuild these. The lines were very messy, i.e., there were a lot of duplicate curves/overlapping curves.
    I have cleaned it up as best I can, however, once I send it to dxf format, it does split the curves up a bit.
    See if this helps.
    Rob
    Jul 2006
    55
    Quote Originally Posted by spoiledbrat View Post
    See if this helps.
    Rob
    Thanx for the effort, but sadly it didnt work out.
    When trying to set the offset in lazycam the arcs went bananas and screwed up my drawing.
    but thanks anyway, mabye ill try the tracing
    best reg cory
    Sep 2006
    43
    Have you tried using the OVERKILL command in Autocad? I am not completely sure what it does but I know it deletes duplicate items and joins all colinear segements. It will also convert Plines to lines and arcs. It has fixed alot of problems for me when importing drawings from ACAD to Enroute
    Sep 2006
    43
    Here is your DWG with the Overkill command applied to all objects. It deleted several thousand duplicates. I have put revision clouds around some geometry that doesn't meet and needs some work extending and/or trimming to limits. Good luck !!!
    Jul 2006
    55
    Hmmm. interesting Dan
    Where do I find the overkill command in acad?
    I was not able to run the file that you posted, it says: Drawing file is not valid.
    I run Acad 2006, version problem mabye?
    Best reg
    Cory
    Sep 2006
    43
    Here it is in 2004DWG format. To run overkill command just type Overkill in the command line and a wizard with options opens. I am unclear on the full capacity of this command and the effect of some of the options. help menu is only somewhat helpful. Good Luck!!!
    Quote Originally Posted by corydoras View Post
    It's part of the Express tools. Under the Express menu, Modify, Delete duplicate objects.
    Apr 2006
    113
    here is one of the parts I traced over..took about 10 min
    Jim
    Jul 2006
    55
    Thanx for the effort guys.
    The last file worked out ok Dan
    The curves where a little sharp for making a good airfoil Jim, but thanx for giving it a shot, I appriciate it.
    I testet the overkill command on another PC at work, and it removed 1563 duplicates, not bad.
    Still struggeling to join all the short lines
    Best reg
    Cory
  1. The real reason for flood cooling... chip cleanup?
    By InspirationTool in forum MetalWork Discussion
    Last Post: 09-13-2012, 08:02 AM
  2. No dxf/cad drawings
    By plexer in forum Uncategorised WoodWorking Machines
    Last Post: 08-14-2010, 06:33 PM
  3. Initial cleanup questions?
    By thackman in forum Syil Products
    Last Post: 11-22-2007, 07:15 PM
  4. Q: X3 Cleanup/Lapping/Setup
    By Deviant in forum Benchtop Machines
    Last Post: 09-04-2006, 02:40 AM
  5. Wet chip cleanup. Blech!
    By Cowbell in forum MetalWork Discussion
    Last Post: 01-21-2006, 06:44 PM
