586,111 active members*
3,652 visitors online*
    May 2006
    265
    orient of livetool
    Is there a way to launch the livetool orient that the machine does before changing tool from a program, just like a spindelorient, but it is on the live tool? I know that it is possible to switch K-relay to get this done just buy pressing the jog button,. I were thinking of a typical arbor operation, and then move tool to clearence in the dia, befor moving it out of the hole.. Any ides anyone?..
    2932
    If I'm not mistaken, the live tool always stops at the same orientation with M35.
    May 2006
    265
    mabe it does, checking it out on monday.
    Nov 2007
    13
    Yep m35. And if your luck enough to have a twin turret lower is m135.
  1. spindle orient
    By nitemare in forum Daewoo/Doosan
    Last Post: 03-14-2013, 05:30 PM
  2. Hurco MD1 spindle orient
    By caleb505 in forum HURCO
    Last Post: 11-25-2007, 02:14 AM
  3. Replies: 2
    Last Post: 01-24-2007, 06:56 PM
  4. Spindle orient and A axis smoothing
    By 1ctoolfool in forum Haas Mills
    Last Post: 11-23-2006, 05:38 AM
  5. Spindle will not orient at tool change
    By chipsahoy in forum Fadal
    Last Post: 07-17-2006, 02:39 AM
