586,111 active members*
3,474 visitors online*
Results 1 to 7 of 7
    259
    Gear cutting on the X3 CNC
    Four video's uploaded to You Tube on the X3 mill.
    http://www.youtube.com/user/John5tevenson
    Enjoy.
    John S.
    May 2006
    1469
    Good work John.
    Is that the bench wobbling or the camera?
    Greg
    Jul 2004
    601
    Yikes, that would be the bench shaking!
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    259
    It's the stand, These were shot whilst it was on it's show transport stand C/W castors.
    Rapids on this are about 120 in / min so it does throw itself round a bit.
    John S.
    Jun 2006
    2512
    Hi John,
    What type of cutter were you using for the herringbone and helical gears.
    Thanks:cheers:
    Phil
    259
    Phil,
    Actually it was a bit of a bodge as it's a straight sided rack cutter off another job. It was done more to test the software program than to generate a correct gear.
    I have since ground up some D bits with the correct involute but as yet haven't cut any more gears, maybe next week as I have a machine to test.
    Jun 2006
    2512
    Hi John
    Thanks for the feedback.
    Have you considered to use the mill to produce the involute, with the blank in the spindle and a single point lathe tool in a vise on the table.
    Also it seems to me there are a whole range of possibilities to produce gear cutters using a CNC mill, especially with a 4th axis.
    Phil
    Quote Originally Posted by John S. View Post
    Phil,
  1. need x3 dimensions for gear cutting
    By dbraun in forum Benchtop Machines
    Last Post: 02-04-2011, 01:46 PM
  2. Gear cutting
    By watchman in forum MetalWork Discussion
    Last Post: 02-15-2007, 01:12 PM
  3. gear cutting software
    By DrStein99 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2006, 05:29 PM
  4. Gear Cutting
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 06-02-2004, 12:30 AM
  5. Gear cutting
    By danswen in forum MetalWork Discussion
    Last Post: 11-04-2003, 06:27 PM
