586,114 active members*
3,046 visitors online*
    Nov 2007
    27
    TM 1 turret rotate fault
    I have a 2000 TM 1 that has run with no problems since we sat it on the floor in Nov. 2000. Now it has started a turret rotate fault when indexing and it happening more and more. Any suggestions would be appreciated.
    Jul 2005
    12177
    Very often turret index faults are due to contamination on the proximity sensors or microswitches. There are two; one detects the position for tool 1 and the other counts the number of tool spaces. They are not easy to see but if you remove all the tools, do a tool change using 5% Rapid and hit Estop while the spindle is lifting you can see inside the changer. There is a sensor on the track for the shuttle so you can see what they look like and you will see the two inside. If they have a chip stuck on them that will be your problem. If they are microswitches they may be gummed up with coolant residue.
    Nov 2007
    27
    You are right they must be hard to see, I have'nt found them yet.
    Jul 2005
    12177
    Have a look at the picture in the first post in this thread.
    http://www.cnczone.com/forums/showthread.php?t=22545
    Nov 2007
    27
    That was it, running for 4 hrs with no turret fault. Knocking on wood.
    Thanks for your help
  1. V2007 Rotate
    By TZ250 in forum BobCad-Cam
    Last Post: 10-14-2007, 06:39 PM
  2. R2E3 quill rotate?
    By cut more in forum Bridgeport / Hardinge Mills
    Last Post: 09-13-2007, 12:38 PM
  3. Rotate and copy
    By bdrmachine in forum Solidworks
    Last Post: 02-03-2007, 04:56 AM
  4. Bolt on Turret 'v' VDI Turret
    By scappini in forum MetalWork Discussion
    Last Post: 07-20-2006, 12:59 PM
  5. copy and rotate, help (okuma)
    By zooloader in forum G-Code Programing
    Last Post: 06-27-2005, 01:01 AM
