586,320 active members*
3,848 visitors online*
Results 1 to 11 of 11
    Jan 2007
    118
    FANUC-KEEPRELAYS
    CAN ANYBODY HELP ME BY GIVING THE INDIVIDUAL BITS DESCRIPTION OF KEEPRELAYS FUNCTION .
    THANKS
    CHANDRU
    Nov 2003
    98
    These will be up to the Machine Builder. Please post Name and Model and someone may be able to help or contact MTB.
    Bob
    Aug 2007
    793
    Usually these bits being used in the LAD programs on PLC. You may block up or activate any line of LAD, where separate bits are used. They being named OP... If you have an opportunity to look at LAD you have to find them there. As for me, i have blocked up the "open door alarm" on Tsugami NU4B (controller 10T).
    Jan 2007
    118
    THANKS
    THANKS FRIENDS,
    BUT I WAS TOLD THAT THERE ARE SOME KEEPRELAYS WHICH ARE RESERVED BY FANUC.
    IS IT SO?
    CHANDRU
    Dec 2006
    84
    That's correct, but some of them are control specific. For example, you can block out the ladder edit function on some of the controls by a keeprelay.
    What control are you working with? Any specific keep bits you're looking for or just a general list?
    Nov 2005
    219
    How do you find the keep relay that operates the open door alarm?? I have found it in the ladder but dont know how to find the right keeprelay.
    Aug 2007
    793
    Quote Originally Posted by theemudracer View Post
    In my ladder door alarm is the line 26F. Item OP7 (K000.7).
    This means: keeprelay #0, bit 7. Reset this bit and check the result in the ladder. If you resetted the proper bit, the "normal open contact OP7" becomes dim. Bit 7 - 1st at the left.
    Jun 2006
    31
    Keep relays
    Quote Originally Posted by guhl View Post
    Hi
    What is the meaning and its use of 26F and how to reset keeprelay bit?
    Thank
    Aug 2007
    793
    Quote Originally Posted by duccnc View Post
    Hi
    Thank
    Hi.
    First of all, set PWE bit in 8000 parameter.
    26F means: page 26 of ladder listing, F - string on the page.
    What type of the controller on your machine? If 10 series, push key "NC/PC", then push software key (on the CRT) "keeprelay". And then set or reset bits in bytes you see on the screen.
    Jun 2006
    31
    Hi.
    Hi guhl
    It' s FANUC system 0MC
    Aug 2019
    27
    Quote Originally Posted by CHANDRU View Post
    THANKS FRIENDS,
    IS IT SO?
    CHANDRU
    I have few explanation of keeprelay settings.
    K17#0 protect pmclad display (0=unprotect 1=protect)
    K17#1 programmer enable (0=off 1=on)
    K17#2 Ladder start (0=auto 1=manual)
    K17#4 Ram write enable (0=no 1=yes)
    K17#5 Signal trace (0=manual 1=auto)
    K17#7 Pmc param. data table screen (0=show 1=hide)
    K18#2 Signal trigger start (0=manual 1=auto)
    there are some differences for the different types. For complete information, please refer to the manual B-61863E / 15 page 484.
  1. Replies: 1
    Last Post: 04-14-2014, 07:41 PM
  2. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
  3. Replies: 7
    Last Post: 11-17-2013, 01:46 AM
  4. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
