my part looks kinda like a shallow tray with a small projection sticking out
3 questions;
a) Should i run surface rough pocket and then surface rough contour or the other way?
b) When i run rough restmill,it eats into the walls of the tray though i asked it to finish the leftovers of the previous op.
c) The depth of the projection doesn't seem to be enough.can i measure the graphic from verify.
i am using mcam9
