Ok, i got my machine running. Still trying to tune it, but seems like it runs.
I don't currently have the machine E-stop hooked up to the PC. I know i need to do this, and it's on my "to-do list" but how? I'm using all my regular input pins. i have 4 limit / home switches (XYZA), and a tool probe hooked up. I have no more pins.
Can i use pin 01 as an input to the PC for the E-stop? Or is it only an output? I've read both online. In most parallel port documentation, pin 01 is output only, but in the emc2 documentation it says i can hook an external switch to pin 1. Can i, or is this an error in the docs? I don't want to fry my port.
The last paragraph before the footnotes
"This assumes an ESTOP switch connected to pin 01 on the parport....."
http://www.linuxcnc.org/docs/2.1/htm...r/stepper.html
