586,477 active members*
3,771 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Solid Extrude Cut Body
    Oct 2007
    145
    I have a bunch of wireframe bolt hole circles. It would be nice to be able to select all of the wireframe bolt hole circles at once and use extrude cut body on all of them so they cut through the solid. Right now I chain the wireframe bolt hole circles by single selecting each one. Some of the bolt holes will work and cut thorough the solid body and some will not if I try and do them all at once. The only way I can get all the holes to cut through with Extrude Cut Body is by selecting each wireframe circle individually and using Extrude Cut Body on them one at a time. I would rather do them all at once. I notice that some holes have the chaining arrow pointing the wrong way and need to be reversed. What causes this and is there a better way to use Extrude Cut Body on all the wireframe bolt holes at once rather than one at a time?
    Sep 2007
    217
    Have you tired using the window function when grabbing the chains? This will most times keep the chains all going in the right direction. Also in the solid Parameters you can pick both directions and if it will not hurt another direction of the part this will also solve chains going the wrong direction.
    Oct 2007
    145
    Okay, I will try using your suggestions. Thank you.
  1. les paul solid body
    By stukent in forum Musical Instrument Design and Construction
    Last Post: 03-13-2020, 09:04 PM
  2. Extrude to multiple surface
    By Craigpat in forum Solidworks
    Last Post: 10-24-2007, 01:31 PM
  3. extrude from planar curve
    By smoker in forum Rhino 3D
    Last Post: 03-21-2007, 11:50 PM
  4. extrude slot at angle
    By PETE1968 in forum Autodesk
    Last Post: 04-11-2006, 02:01 AM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
