586,102 active members*
3,274 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Help with Okuma flat turning
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2007
    38
    Have been trying unsuccessfully on an OSP5020.
    Anybody actually have experience with this?
    Nov 2007
    38
    No one?
    Have tried to get tech support from Okuma. They say they've never done it and sort of good luck with that.
    Feb 2003
    349
    Quote Originally Posted by rick kroeze View Post
    No one?
    hi
    i have a lb15 with 5020?
    how can i help u?
    Nov 2007
    38
    Phx,
    Do you have the M version... live tooling with the option to do flat turning turned on? (M220-M226)
    Feb 2003
    349
    Phx,
    hi
    i have the 5020 without M, and i dont know what the englisch word Flat turning stays for.
    i have a OSP 7000 with M.
    regards
    Nov 2007
    38
    Might be the same on the OSp7000. If you try a M221 do you get an alarm? If so it doesn't have the flat turning option
    Flat turning is a fast process of putting a polygon on a part. It is much faster than doing a X-C contouring operation, although not as accurate. Sometimes it's called poly turning.
    If you wanted a part with a hexagon you do approximately as follows:
    G50S3000
    M5
    M222
    M3S500
    G0X500Z10
    Z-5
    G1X200F1
    X500
    G0Z10
    M5
    M220
    M2
    Using a 3 flute cutter this should produce a hexagon on the part. The whole program works with no error codes but does not produce the flats. All it does is put 6 equal spaced marks in the part.
    Jun 2005
    194
    Flat Turn
    See if this helps any (see attached)... Also, make sure you have the tool type defined correctly.
    Good Luck,
    Attached Files Attached Files
    JR Walcott
    Georgia Machine Tool Resources, LLC
    Nov 2007
    38
    JR Walcott,
    Thanks for the attempt.
    Already have those pages. Using that format it doesn't seem to generate the flats. That's the problem. The spindle sync happens but that's it. Some other puzzle piece is required.
    Rick
    Jan 2004
    33
    I think you are hobbing instead of flat turning. Try turning the work spindle the other direction.
    Rodman
    Nov 2007
    38
    Reversing the work spindle also automatically reverses the M-tool spindle. That would require using left hand tooling. That said I don't see any difference. It still seems to be, as you say, more of a hobbing operation. No motion (change in phase of the two spindles) seems to be happening.
    Jan 2004
    33
    Please describe your cutter, diameter and shape, also part diameter.
    Rodman
    Nov 2007
    38
    Rodman,
    Had attempted with 1" dia stock, putting a .875 hex on it. Using a .75 3 flute cutter.
    It was just a test so can change anything.
    Have you done this before?
    Rick
    Jan 2004
    33
    That explaines it. Try using a bigger cutter, at least 3''. The cutting action will come from the difference in circumferences and surface speeds. See a demo here, click on product video. Flat turning=Polygon turning=Profilating, basically the same process.
    Nov 2007
    38
    See a demo where?
    Nov 2007
    38
    Also, do the cutting teeth have to be oriented in the holder in the M spindle?
    Jun 2005
    194
    Rick,
    Okuma's Customer Support standards are extremely high. If your local dealer can't help you, try emailing Okuma for support ([email protected]). As an ex Okuma user, service tech. & salesman I'm confident that the level of support you will find, will meet if not exceed your expectations.
    Good Luck,
    JR Walcott
    Apr 2009
    1262
    Re: Help with Okuma flat turning
    Sorry I missed this post. I have done it many times. You will be needing a larger cutter diameter to make it work better. the smaller the cutter it is to the desired diameter, the more of an arc will be generated.
    Hope you got it working...sorry I missed the party...did it clear back in the 80's!
    Best regards,
    PS> who did you get your polygon head from?
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    i am sure you reached this one by a link somewhere ... i hope you are not digging otherwise, it means that you are bored
    come on, this thread is way too easy for you
    Dec 2008
    3109
    Come on you guys
    This thread is 9 years old ...... (flame2)
    Apr 2009
    1262
    Yes, I stumbled on it looking for polygon head info and it made me smile as I took a trip down memory lane. Anybody have any sources for polygon heads? I've got another job that needs them, but they seem to be hard to come by...thus my search
    I can get lots of cutters through PH Horn, but the head (body) is more difficult. They were typically built with much heavier bearings and mass than a standard live tool.
    Thanks for the flaming Superman...I probably deserved it! I guess I should have just started another post rather than hijack this one...but hey...It's a dead one anyway - except for he's maybe got a polygon head and knows the source, right?
    Best regards,
    PS> Superman, did you move from krypton to be closer to kittens?
Page 1 of 2 12
  1. Turning Okuma OSP700L Alarm 128!
    By kakashi in forum Okuma
    Last Post: 04-11-2022, 07:45 PM
  2. Balance turning in Okuma Macturn
    By zooloader in forum Videos
    Last Post: 09-29-2010, 09:31 AM
  3. Considering buying flat turning option
    By ProToZyKo in forum Okuma
    Last Post: 04-14-2010, 02:33 PM
  4. Okuma LB-10 Turning Center
    By Dwayne Foy in forum Okuma
    Last Post: 11-06-2009, 02:53 PM
  5. Looking for help with Okuma turning center.
    By shawn45223 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2007, 12:06 AM
